Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: WESLEY PHILLIPS on 27-06-2011 05:48:04 PM I am trying to run a script on a voice gateway. The script runs when the call arrives, and the processing runs as expectedx until it gets to the act_Authenticated subroutine. Here is the act_Authenticated routine: proc act_Authenticated { } { global param1 global param global dnis global fcnt global retryCnt set status [infotag get evt_status] puts "\n@@@@status=$status" if { ($status == "au_000") || ($status == "au_001") } { leg setup $dnis callInfo leg_incoming fsm setstate PLACECALL return } else { leg setup 18001234567 callInfo leg_incoming fsm setstate PLACECALL } } I want the script to place the call when the radius server retuens an authentication success ("au_000") and also then the radius server is unavailable("au_001"), and redirect to a different number on authentication failure. The problem I am having is when the radius server is unavailable. The authentication fails as expected, and the script tries to set up the outbound call leg, but I get the following error after the leg setup command is executed: Jun 24 16:08:59.955: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not found for tag(56) Jun 24 16:08:59.955: //4074//OSP :/Dest_Settlement_MatrixCheck: retcode=2 cid(4074) trans=0x0, provider=0 User is not authenticated and not roaming Jun 24 16:08:59.955: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (OSP Fail): IEC=1.1.228.11.32.0 on callID 4074 GUID=3BC7C2049DB311E081A59A670DD4F946 Is there a variable that I can change to make the script think that the authentication succeeded in this scenario so that the call will complete? The aaa command that I am using is "aaa authenticate" command, which shouldn't return any AV pairs, so I am at a loss as to why the calls will not complete. Any help would be appreciated. thanks
Subject: RE: authentication problem Replied by: WESLEY PHILLIPS on 28-06-2011 09:27:53 AM here is the full script:
proc init { } { global param global param1 global retryCnt
set param(interruptPrompt) true set param(abortKey) * set param(terminationKey) #
set param1(interruptPrompt) true set param1(abortKey) * set param1(terminationKey) # set param1(dialPlan) true if { [infotag get cfg_avpair_exists retry-count] } { set retryCnt [infotag get cfg_avpair retry-count] } else { set retryCnt 3 }
} proc init_perCallVars { } { global beep global fcnt set fcnt 0 set beep 0 } proc act_Setup { } { global dnis
init_perCallVars
leg setupack leg_incoming leg proceeding leg_incoming leg connect leg_incoming set ani [infotag get leg_ani] set dnis [infotag get leg_dnis] aaa authenticate $ani $dnis }
leg setup 8326682500 callInfo leg_incoming fsm setstate PLACECALL } }
proc act_PromptCollect_acct { } { global account global param global fcnt
set status [infotag get evt_status] if { ($status == "cd_002") || ($status == "cd_007") || ($status == "cd_001") || ($status == "cd_006") } {
#enter account NO: set pattern(account) .+
leg collectdigits leg_incoming param pattern if { $fcnt == 0 } { media play leg_incoming flash:enter_account.au } else { media play leg_incoming flash:auth_fail_retry.au }
fsm setstate samestate return }
if {$status == "cd_005"} { set account [infotag get evt_dcdigits]
set pattern(account) .+ leg collectdigits leg_incoming param pattern media play leg_incoming flash:enter_pin.au }
proc act_PromptCollect_pass { } { global pin global account global param global fcnt
set status [infotag get evt_status] #Aborted if {$status == "cd_002"} { #enter account NO: set pattern(account) .+
leg collectdigits leg_incoming param pattern if { $fcnt == 0 } { media play leg_incoming flash:enter_account.au } else { media play leg_incoming flash:auth_fail_retry.au } fsm setstate GETACCOUNT return }
#timeout/invalid number if { ($status == "cd_001") || ($status == "cd_006") || ($status == "cd_007") } { set pattern(account) .+ leg collectdigits leg_incoming param pattern media play leg_incoming flash:enter_pin.au fsm setstate samestate return }
if {$status == "cd_005"} { set pin [infotag get evt_dcdigits]
aaa authenticate $account $pin
proc act_PromptCollect_dest { } { global dest global param1
set param(dialPlan) true leg collectdigits leg_incoming param1 media play leg_incoming flash:enter_destination.au fsm setstate GETDEST return } #matched dialplan if {$status == "cd_004"} { set dest [infotag get evt_dcdigits] leg setup $dest callInfo leg_incoming } }
proc act_CallSetupDone { } { global beep set status [infotag get evt_status]
if { $status == "ls_000"} {
set creditTimeLeft "unlimited" if { $creditTimeLeft == "unlimited" } { puts "\n Unlimited Time" } else { # start the timer for ... if { $creditTimeLeft < 10 } { set beep 1 set delay $creditTimeLeft } else { set delay [expr $creditTimeLeft - 10] } timer start leg_timer $delay leg_incoming } } else { set tone [infotag get evt_status] playtone leg_incoming $tone timer start leg_timer 5 leg_incoming fsm setstate CALLDISCONNECT } }
proc act_Timer { } { global beep global incoming global outgoing
set incoming [infotag get leg_incoming] set outgoing [infotag get leg_outgoing] if { $beep == 0 } { #insert a beep ...to the caller connection destroy con_all set beep 1 } else { connection destroy con_all fsm setstate LASTWARN } }
proc act_LastWarn { } { media play leg_incoming flash:out_of_time.au }
proc act_Destroy { } { media play leg_incoming flash:beep.au }
proc act_Beeped { } { global incoming global outgoing
connection create $incoming $outgoing }
proc act_ConnectedAgain { } { #get the timer value again and start the timer ??? #set delay [infotag get VARTAG] timer start leg_timer 10 leg_incoming }
#---------------------------------- # State Machine #----------------------------------
set fsm(any_state,ev_disconnected) "act_Cleanup,samestate" set fsm(CALL_INIT,ev_setup_indication) "act_Setup AUTHENTICATE" set fsm(AUTHENTICATE,ev_authenticate_done) "act_Authenticated GETDEST"
set fsm(GETACCOUNT,ev_collectdigits_done) "act_PromptCollect_acct GETPASSWORD" set fsm(GETPASSWORD,ev_collectdigits_done) "act_PromptCollect_pass AUTHENTICATE"
set fsm(GETDEST,ev_collectdigits_done) "act_PromptCollect_dest PLACECALL"
set fsm(PLACECALL,ev_setup_done) "act_CallSetupDone CALLACTIVE"
set fsm(CALLACTIVE,ev_leg_timer) "act_Timer INSERTBEEP" set fsm(INSERTBEEP,ev_destroy_done) "act_Destroy samestate" set fsm(INSERTBEEP,ev_media_done) "act_Beeped samestate" set fsm(INSERTBEEP,ev_create_done) "act_ConnectedAgain CALLACTIVE" set fsm(LASTWARN,ev_destroy_done) "act_LastWarn CALLDISCONNECT"
set fsm(CALLACTIVE,ev_disconnected) "act_Cleanup CALLDISCONNECT" set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup samestate" set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup samestate" set fsm(CALLDISCONNECT,ev_leg_timer) "act_Cleanup samestate"
fsm define fsm CALL_INIT
and here is the output of the call with the requested debugs:
Jun 28 13:29:22.048: //-1//SCRI:/ScriptList_CacheCurrent: auth Jun 28 13:30:17.996: //4107/CD699A0981E7/VAAA:0/voip_start_ccapi_accounting: WARNING: gw-accounting aaa not enabled. return. Jun 28 13:30:17.996: //-1//SERV:/AFW_Service_CCInterface: Received Event 25 for service auth modulehandle NULL Jun 28 13:30:17.996: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = auth Jun 28 13:30:17.996: //-1//AFW_:/AFW_Process_New: auth Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Process(Size=128) Jun 28 13:30:17.996: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x30E813F4, Type: ProcManager, RefCount: 2 Jun 28 13:30:17.996: //-1//AFW_:/AFW_ExecEnv_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: ExecEnv(Size=232) Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_SetRoot: Execenv = 0x31D29988 Jun 28 13:30:17.996: //-1//AFW_:/AFW_TclModule_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: TclModule(Size=368) Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 28 13:30:17.996: //-1//AFW_:/AFW_Process_Lock: pProcess(0x3144780C)=1 Jun 28 13:30:17.996: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x3144780C, Type: Process, RefCount: 2 Jun 28 13:30:17.996: //-1//AFW_:LP:EE31D29988000:HN1EC3E108:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0 Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_SetScript: Script Name = auth, Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_SetScript: Script URI = http://172.17.2.10/auth.tcl Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x30E80C10, Type: Service, RefCount: 3 Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetParamArray: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31CE4834, Type: DataArray, RefCount: 3 Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: auth, type: PackTable Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = auth, Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = http://172.17.2.10/auth.tcl Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = Tcl Script Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/Tcl_Link: Linking script auth Jun 28 13:30:17.996: //-1//PACK:EE31D29988000:/PkgRequire: name(tcl20base) version() exact(0) rootScript(auth) Jun 28 13:30:17.996: //-1//PACK:/find_global_package_entry: pkgName(tcl20base) exact(0) Jun 28 13:30:17.996: //-1//PACK:EE31D29988000:/PkgRequire: Linking package tcl20base Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296EDC34, Type: Package, RefCount: 16 Jun 28 13:30:17.996: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: tcl20base, type: PackTable Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = tcl20base, Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:tcl20base_package.C Jun 28 13:30:17.996: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:17.996: //-1//PACK:EE31D29988000:/PkgProvide: name(tcl20base) version(1.0) rootScript(auth) Jun 28 13:30:17.996: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:17.996: //-1//PACK:EE31D29988000:/PkgRequire: name(tclcore) version() exact(0) rootScript(auth) Jun 28 13:30:17.996: //-1//PACK:/find_global_package_entry: pkgName(tclcore) exact(0) Jun 28 13:30:17.996: //-1//PACK:EE31D29988000:/PkgRequire: Linking package tclcore Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:17.996: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:17.996: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296EDA14, Type: Package, RefCount: 20 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: tclcore, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = tclcore, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:tclcore_package.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(tclcore) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(tclmodule) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(tclmodule) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package tclmodule Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296ED3B4, Type: Package, RefCount: 21 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: tclmodule, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = tclmodule, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:TclModule.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(tclmodule) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(media) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(media) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package media Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296ED4C4, Type: Package, RefCount: 53 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: media, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = media, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:package_media.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:/CMeth_MediaPkg_Main: Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(media) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(session_xwork) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(session_xwork) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package session_xwork Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DF42C, Type: Package, RefCount: 49 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: session_xwork, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = session_xwork, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:Session_XWork.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(session_xwork) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(digitcollect) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(digitcollect) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package digitcollect Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DEBAC, Type: Package, RefCount: 50 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: digitcollect, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = digitcollect, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtinigitCollect.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(digitcollect) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(callsetup) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(callsetup) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package callsetup Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DF0FC, Type: Package, RefCount: 55 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: callsetup, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = callsetup, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:CallSetup.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(callsetup) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(preempt) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(preempt) exact(0) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgVersion(1.0) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package preempt Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DEFEC, Type: Package, RefCount: 56 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: preempt, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = preempt, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtinreempt.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(preempt) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(Retrieval) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(Retrieval) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package Retrieval Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version NULL for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DF20C, Type: Package, RefCount: 50 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: Retrieval, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = Retrieval, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:Retrieval.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(Retrieval) version(NULL) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(NULL) v2(NULL) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(session_xwork) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(media) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(consult) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(consult) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package consult Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DEDCC, Type: Package, RefCount: 50 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: consult, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = consult, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:Consult.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(consult) version(1.0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: name(consultresp) version() exact(0) rootScript(auth) Jun 28 13:30:18.000: //-1//PACK:/find_global_package_entry: pkgName(consultresp) exact(0) Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgRequire: Linking package consultresp Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.000: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.000: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DEEDC, Type: Package, RefCount: 50 Jun 28 13:30:18.000: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: consultresp, type: PackTable Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = consultresp, Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:ConsultResp.C Jun 28 13:30:18.000: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.000: //-1//PACK:EE31D29988000:/PkgProvide: name(consultresp) version(1.0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: name(appcommon) version() exact(0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/find_global_package_entry: pkgName(appcommon) exact(0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: Linking package appcommon Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DEA9C, Type: Package, RefCount: 52 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: appcommon, type: PackTable Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = appcommon, Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:AppCommon.C Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgProvide: name(appcommon) version(1.0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/ParamRead: Reading param security from appcommon Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Reading parameter security for a script appcommon, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: appRegParams=0x312ADF8C dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 28 13:30:18.004: //-1//PACK:/ParamRead: service level: script appcommon, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param appcommon.security Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Param appcommon.security was not found in this container Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Parameter for the script: appcommon has been read: security Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//ACPK:EE31D29988000:/AppCommon_SetSecurity: security = undefined Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/ParamRead: Reading param event-log from appcommon Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Reading parameter event-log for a script appcommon, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: appRegParams=0x312ADF8C dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 28 13:30:18.004: //-1//PACK:/ParamRead: service level: script appcommon, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param appcommon.event-log Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Param appcommon.event-log was not found in this container Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Parameter for the script: appcommon has been read: event-log Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//ACPK:EE31D29988000:/AppCommon_SetEventLog: event-log = unconfigured Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: name(callfeature) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/find_global_package_entry: pkgName(callfeature) exact(0) Jun 28 13:30:18.004: //-1//PACK:/find_global_package_entry: pkgVersion(1.0) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: Linking package callfeature Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DECBC, Type: Package, RefCount: 52 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: callfeature, type: PackTable Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = callfeature, Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:CallFeature.C Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgProvide: name(callfeature) version(1.0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: name(english) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/find_global_package_entry: pkgName(english) exact(0) Jun 28 13:30:18.004: //-1//PACK:/find_global_package_entry: pkgVersion(1.0) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: Linking package english Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.004: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296ED5D4, Type: Package, RefCount: 50 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: english, type: PackTable Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = english, Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:package_english.C Jun 28 13:30:18.004: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgProvide: name(english) version(1.0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: name(media) version() exact(0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/ParamRead: Reading param index from english Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Reading parameter index for a script english, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: appRegParams=0x296EE3C0 dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 28 13:30:18.004: //-1//PACK:/ParamRead: service level: script english, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param english.index Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Parameter for the script: english has been read: index Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//PACK:/Lang_ReportConfig: index=1 Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/ParamRead: Reading param location from english Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Reading parameter location for a script english, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: appRegParams=0x296EE3C0 dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 28 13:30:18.004: //-1//PACK:/ParamRead: service level: script english, Jun 28 13:30:18.004: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 28 13:30:18.004: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param english.location Jun 28 13:30:18.004: //-1//PACK:/ParamRead: Parameter for the script: english has been read: location Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//PACK:/Lang_ReportConfig: location=flash: Jun 28 13:30:18.004: //-1//AFW_:/AFW_ExecEnv_CallProc: Media::Register_Language Jun 28 13:30:18.004: //-1//PACK:/CMeth_Register_Language: Jun 28 13:30:18.004: //-1//PACK:/CMeth_Register_Language: Register namespace english index 1 language en, Jun 28 13:30:18.004: //-1//PACK:/CMeth_Register_Language: prefix en location flash: Jun 28 13:30:18.004: //-1//PACK:/CreateLanguageElement: Create language with namespace english, index 1, language code en Jun 28 13:30:18.004: //-1//PACK:/CreateLanguageElement: prefix en, location flash: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x2A658F40 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x2A644CF8 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: element 0x30078F74 containing 0x2A658F40, Prev = 0x0 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x2A658E64 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: element 0x30078F74 containing 0x2A658F40, Prev = 0x0 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: element 0x3005071C containing 0x2A644CF8, Prev = 0x30078F74 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: element 0x29E76C60 containing 0x2A644CE4, Prev = 0x3005071C Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetWrapper: element 0x2A350F84 containing 0x30054B90, Prev = 0x29E76C60 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 28 13:30:18.004: //-1//PACK:/AddLanguageElementToLangTbl: Adding the language en to the language table Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSetNameSpace: Adding param space media, name en, entryKey en.media, type DataList Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: en.media, type: DataList Jun 28 13:30:18.004: //-1//PACK:/Media_GetFirstLanguage: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x30078F74, with Instance = 0x2A658F40 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetNext: Elem = 0x3005071C, with Instance = 0x2A644CF8, Prev = 0x30078F74 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x30078F74, with Instance = 0x2A658F40 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetNext: Elem = 0x3005071C, with Instance = 0x2A644CF8, Prev = 0x30078F74 Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataList_GetNext: Elem = 0x29E76C60, with Instance = 0x2A644CE4, Prev = 0x3005071C Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_Get: Jun 28 13:30:18.004: //-1//PACK:/CMeth_Register_Language: Setting en as the current language Jun 28 13:30:18.004: //-1//PACK:/Media_Cur_Language_SetByLangCode: Attempting to set en as the current language Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataString_New: Jun 28 13:30:18.004: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 28 13:30:18.004: //-1//PACK:/Media_Cur_Language_SetByLangCode: Setting en as the current language Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSetNameSpace: Adding param space media, name Curent_Language, entryKey Curent_Language.media, type DataString Jun 28 13:30:18.004: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: Curent_Language.media, type: DataString Jun 28 13:30:18.004: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x2A658EF0, Type: DataString, RefCount: 2 Jun 28 13:30:18.004: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A658EF0, Type: DataString, RefCount: 1 Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.004: //-1//PACK:EE31D29988000:/PkgRequire: name(media) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.004: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgRequire: name(medianeg) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.008: //-1//PACK:/find_global_package_entry: pkgName(medianeg) exact(0) Jun 28 13:30:18.008: //-1//PACK:/find_global_package_entry: pkgVersion(1.0) Jun 28 13:30:18.008: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgRequire: Linking package medianeg Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.008: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.008: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296DF31C, Type: Package, RefCount: 50 Jun 28 13:30:18.008: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: medianeg, type: PackTable Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = medianeg, Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:MediaNeg.C Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgProvide: name(medianeg) version(1.0) rootScript(auth) Jun 28 13:30:18.008: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.008: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgRequire: name(callsnr) version(1.0) exact(0) rootScript(auth) Jun 28 13:30:18.008: //-1//PACK:/find_global_package_entry: pkgName(callsnr) exact(0) Jun 28 13:30:18.008: //-1//PACK:/find_global_package_entry: pkgVersion(1.0) Jun 28 13:30:18.008: //-1//PACK:/ComparePkgVersions: v1(1.0) v2(1.0) Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgRequire: Linking package callsnr Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_New: Jun 28 13:30:18.008: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: PackTable(Size=36) Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetVersion: Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetVersion: setting version 1.0 for the package Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetSettings: Jun 28 13:30:18.008: //-1//AFW_:/AFW_PackTable_SetScript: Jun 28 13:30:18.008: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x296EDD44, Type: Package, RefCount: 35 Jun 28 13:30:18.008: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: callsnr, type: PackTable Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script Name = callsnr, Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script URI = builtin:CallSnr.C Jun 28 13:30:18.008: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Link: Script type = C Script Jun 28 13:30:18.008: //-1//PACK:EE31D29988000:/PkgProvide: name(callsnr) version(1.0) rootScript(auth)
Subject: RE: authentication problem Replied by: Anusha Kannappan on 28-06-2011 06:50:59 AM Hi Wesley,
Could you please share us the logs enabling the following debugs and if possible do share us your script as well?
deb voip application all deb voip aaa
Thanks, Anusha
Subject: RE: authentication problem Replied by: Anusha Kannappan on 29-06-2011 05:25:13 AM Hi Wesley,
The logs provided by you are not complete. Have you mapped your script to any of the dial-peers or not? We don't see any traces of the script being loaded. Before collecting the logs configure the following cli and clear the logs
! logging buffered 100000000
Map your script to the dial-peer and make a call to invoke the particular script and send us the logs for further analysis.
Thanks, Anusha
Subject: RE: authentication problem Replied by: WESLEY PHILLIPS on 29-06-2011 10:44:09 AM For some reason, when I do the "debug voip app all" command, all the application debugs show up in the "show debug" command, but some of the debugs do not go to the log. Here are some selective debugs:
debug voip app tcl debug voip app script debug voip app error
and here is the output from a single call:
Jun 24 16:08:59.951: //-1//AFW_:EE31D2A0C8000:/Tcl_Link: Linking script auth Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_RequiredVersionObjCmd: Script requires version 2.0. So 2.1 is OK Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_InfotagObjCmd: infotag get cfg_avpair_exists retry-count Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists retry-count Jun 24 16:08:59.951: //-1//AFW_:EE31D2A0C8000:/vtr_cf_avpair_exists: argc 3 argindex 2 Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_InfotagObjCmd: infotag get cfg_avpair retry-count Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair retry-count Jun 24 16:08:59.951: //-1//AFW_:EE31D2A0C8000:/vtr_cf_avpair: argc 3 argindex 2 Jun 24 16:08:59.951: //-1//PACK:EE31D2A0C8000:/tcl_ParamReadObjCmd: retry-count Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_FSMObjCmd: fsm define fsm CALL_INIT Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT Jun 24 16:08:59.951: //-1//TCL :EE31D2A0C8000:/tcl_FSMDefineObjCmd: FSM Data structure Jun 24 16:08:59.951: (INSERTBEEP(2), ev_create_done(36)--(act_ConnectedAgain)-->(CALLACTIVE(3)) Jun 24 16:08:59.951: (CALLDISCONNECT(4), ev_media_done(162)--(act_Cleanup)-->(samestate(5)) Jun 24 16:08:59.951: (CALLACTIVE(3), ev_disconnected(18)--(act_Cleanup)-->(CALLDISCONNECT(4)) Jun 24 16:08:59.951: (LASTWARN(6), ev_destroy_done(37)--(act_LastWarn)-->(CALLDISCONNECT(4)) Jun 24 16:08:59.951: (GETACCOUNT(7), ev_collectdigits_done(210)--(act_PromptCollect_acct)-->(GETPASSWORD(8)) Jun 24 16:08:59.951: (CALLDISCONNECT(4), ev_disconnect_done(19)--(act_Cleanup)-->(samestate(5)) Jun 24 16:08:59.951: (CALLDISCONNECT(4), ev_leg_timer(1)--(act_Cleanup)-->(samestate(5)) Jun 24 16:08:59.951: (INSERTBEEP(2), ev_media_done(162)--(act_Beeped)-->(samestate(5)) Jun 24 16:08:59.951: (PLACECALL(9), ev_setup_done(201)--(act_CallSetupDone)-->(CALLACTIVE(3)) Jun 24 16:08:59.951: (CALLACTIVE(3), ev_leg_timer(1)--(act_Timer)-->(INSERTBEEP(2)) Jun 24 16:08:59.951: (GETPASSWORD(8), ev_collectdigits_done(210)--(act_PromptCollect_pass)-->(AUTHENTICATE(10)) Jun 24 16:08:59.951: (any_state(0), ev_disconnected(18)--(act_Cleanup)-->(samestate(5)) Jun 24 16:08:59.955: (AUTHENTICATE(10), ev_authenticate_done(174)--(act_Authenticated)-->(GETDEST(11)) Jun 24 16:08:59.955: (GETDEST(11), ev_collectdigits_done(210)--(act_PromptCollect_dest)-->(PLACECALL(9)) Jun 24 16:08:59.955: (INSERTBEEP(2), ev_destroy_done(37)--(act_Destroy)-->(samestate(5)) Jun 24 16:08:59.955: (CALL_INIT(1), ev_setup_indication(31)--(act_Setup)-->(AUTHENTICATE(10)) Jun 24 16:08:59.955: FSM start state CALL_INIT(1) Jun 24 16:08:59.955: //-1//AFW_:EE31D2A0C8000:/Tcl_Link: Script auth succesfully linked. Jun 24 16:08:59.955: //4074//TCL :/tcl_LegObjCmd: leg setupack leg_incoming Jun 24 16:08:59.955: //4074//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: argc 2 Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:08:59.955: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:08:59.955: //4074//TCL :/tcl_LegObjCmd: leg proceeding leg_incoming Jun 24 16:08:59.955: //4074//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: argc 2 Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:08:59.955: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:08:59.955: //4074//TCL :/tcl_LegObjCmd: leg connect leg_incoming Jun 24 16:08:59.955: //4074//TCL :/tcl_LegConnectObjCmd: connect leg_incoming Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: argc 2 Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:08:59.955: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get leg_ani Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani Jun 24 16:08:59.955: //4074//AFW_:/vtr_lg_ani: argc 2 argindex 2 Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get leg_dnis Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis Jun 24 16:08:59.955: //4074//AFW_:/vtr_lg_dnis: argc 2 argindex 2 Jun 24 16:08:59.955: //4074//TCL :/tcl_AAAObjCmd: aaa authenticate 7134224200 7134221000 Jun 24 16:08:59.955: //4074//TCL :/tcl_AuthenticateObjCmd: authenticate 7134224200 7134221000 Jun 24 16:08:59.955: //4074//TCL :/tcl_AuthenticateObjCmd: account=7134224200, password=7134221000, methodList=, av-send= Jun 24 16:08:59.955: //4074//TCL :/tcl_AuthenticateObjCmd: Start authenticate failed Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 24 16:08:59.955: //4074//TCL :/tcl_PutsObjCmd: @@@@status=au_001 Jun 24 16:08:59.955: Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get leg_isdid Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get leg_isdid Jun 24 16:08:59.955: //4074//AFW_:/vtr_lg_incdid: argc 2 argindex 2 Jun 24 16:08:59.955: //4074//TCL :/tcl_LegObjCmd: leg setup 7134221000 callInfo leg_incoming Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: argc 4 Jun 24 16:08:59.955: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:08:59.955: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:08:59.955: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not found for tag(56) Jun 24 16:08:59.955: //4074//OSP :/Dest_Settlement_MatrixCheck: retcode=2 cid(4074) trans=0x0, provider=0 User is not authenticated and not roaming Jun 24 16:08:59.955: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (OSP Fail): IEC=1.1.228.11.32.0 on callID 4074 GUID=3BC7C2049DB311E081A59A670DD4F946 Jun 24 16:08:59.955: //4074//TCL :/tcl_FSMObjCmd: fsm setstate PLACECALL Jun 24 16:08:59.955: //4074//TCL :/tcl_FSMSetStateObjCmd: setstate setstate PLACECALL Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 24 16:08:59.955: //4074//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 24 16:08:59.959: //4074//TCL :/tcl_PlayToneObjCmd: playtone leg_incoming ls_003 Jun 24 16:08:59.959: //4074//AFW_:/vtd_lg_incoming: argc 3 Jun 24 16:08:59.959: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:08:59.959: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:09:00.179: //4074//TCL :/tcl_TimerObjCmd: timer start leg_timer 5 leg_incoming Jun 24 16:09:00.179: //4074//TCL :/tcl_TimerStartObjCmd: timer start leg_timer 5 leg_incoming Jun 24 16:09:00.179: //4074//AFW_:/vtd_lg_incoming: argc 4 Jun 24 16:09:00.179: //4074//AFW_:/vtd_lg_incoming: Legs [4074 ] Jun 24 16:09:00.179: //4074//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 24 16:09:00.179: //4074//TCL :/tcl_FSMObjCmd: fsm setstate CALLDISCONNECT Jun 24 16:09:00.179: //4074//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT Jun 24 16:09:05.131: //4074//TCL :/tcl_CallObjCmd: call close Jun 24 16:09:05.131: //4074//TCL :/tcl_CallCloseObjCmd: close
Subject: RE: authentication problem Replied by: Yaw-Ming Chen on 29-06-2011 01:36:49 PM Did you logging console ?
Don't log to console and wait for a moment then collect log conf t no logging console exit
clear log
then start test
after test
term len 0
sh log | red ? (pick the destination you like)
Subject: RE: authentication problem Replied by: Anusha Kannappan on 30-06-2011 03:40:12 AM Hi Wesley,
From the logs provided it is seen that call is getting disconnected as it has received ls_003 which infers that the call setup failed because of a lack of resources in the network and nothing to do with the authentication stuff.
BTW have you modified your script again? Because after getting the status as au_001 it was directly doing a leg setup as per the script you had provided but in the logs it is executing the infotag get leg_isdid. Why there is discripency over here?
Thanks, Anusha
Subject: RE: authentication problem Replied by: WESLEY PHILLIPS on 30-06-2011 09:06:16 AM my apologies. that was a debug from a previous attempted script. I set the logging buffer to a larger value and turned off logging monitor as suggested above. Here is the call with all the debugs originally requested:
Jun 30 13:05:19.024: //-1//SCRI:/ScriptList_CacheCurrent: auth Jun 30 13:06:10.072: //4110/CD63A95A81EC/VAAA:0/voip_start_ccapi_accounting: WARNING: gw-accounting aaa not enabled. return. Jun 30 13:06:10.072: //-1//SERV:/AFW_Service_CCInterface: Received Event 25 for service auth modulehandle NULL Jun 30 13:06:10.072: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = auth Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_New: auth Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Process(Size=128) Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x30E813F4, Type: ProcManager, RefCount: 2 Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D29988, Type: ExecEnv, RefCount: 1 Jun 30 13:06:10.072: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_SetRoot: Execenv = 0x31D29988 Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: TclModule(Size=368) Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_TclModule_NewDup: Jun 30 13:06:10.072: //-1//AFW_:/AFW_DataArray_New: Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: FSM(Size=104) Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x300CDF88, Type: TclModule, RefCount: 0 Jun 30 13:06:10.072: //-1//AFW_:HN1EC4C9C8:/AFW_M_TclModule_Free: MOD[TclModule_300CDF88_0_516153608] ( ) Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A64CA34, Type: FSM, RefCount: 0 Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_FSM_Free: Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A618074, Type: DataArray, RefCount: 0 Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_Lock: pProcess(0x3144788C)=1 Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x3144788C, Type: Process, RefCount: 2 Jun 30 13:06:10.072: //-1//AFW_:LP:EE31D29988000:HN28FA8120:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0 Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_DataArray_NewDup: param_name: Curent_Language, param_namespace: media Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 30 13:06:10.072: //-1//AFW_:/AFW_DataArray_ElementSetNameSpace: Adding param space media, name Curent_Language, entryKey Curent_Language.media, type DataString Jun 30 13:06:10.072: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: Curent_Language.media, type: DataString Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_Initiate: Execenv = 0x31D29988 Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x313DD624, Type: TclModule, RefCount: 2 Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_SetCallCorID: Jun 30 13:06:10.072: CallCorID is Mc)Z"P^Q`^Al^Zg TyF Jun 30 13:06:10.072: //-1//AFW_:/AFW_Leg_New: Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Leg(Size=4872) Jun 30 13:06:10.072: //4110//AFW_:/AFW_M_Leg_SetExecEnv: Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 1 Jun 30 13:06:10.072: //-1//AFW_:LP:EE31D29988000:LG4110:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1 Jun 30 13:06:10.072: //4110//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener Jun 30 13:06:10.072: //4110//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_4110 Jun 30 13:06:10.072: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: LEG_4110, type: Leg Jun 30 13:06:10.072: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 2 Jun 30 13:06:10.072: //-1//AFW_:EE31D29988000:/AFW_ExecEnv_AssignCall: Execenv = 0x31D29988, Leg = 4110, Peer_Tag = 10 Jun 30 13:06:10.072: //4110//AFW_:/AFW_ExecEnv_SetCallCorID: Jun 30 13:06:10.072: CallCorID is Mc)Z"P^Q`^Al^Zg TyF Jun 30 13:06:10.072: //-1//SERV:/AFW_Service_Process_Space: Jun 30 13:06:10.072: Process Started Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_Register: ccAppInitialize(name: _ManagedAppProcess_auth) Jun 30 13:06:10.072: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.072: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.072: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.072: //4110//AFW_:/AFW_Process_GetCcqEvent: Received Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_SETUP_IND(31)] { Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x31D29988] Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[4110][LEG_INIT(0)][Cause(0)] Jun 30 13:06:10.072: //-1//AFW_:/AFW_Process_GetCcqEvent: } Jun 30 13:06:10.072: //4110//SSIN:/AFW_SS_MapEvent: Jun 30 13:06:10.072: //-1//SSIN:/AFW_SS_H323_MapEvent: Jun 30 13:06:10.072: //-1//AFW_:/AFW_Util_SaveRawMsg: Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 842 type 0 Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat for dial-peer [10] Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_Object_ShowListeners: Jun 30 13:06:10.072: //4110//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_313DD624_0_687505696MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[4110][LEG_INCINIT(1)][Cause(0)] Jun 30 13:06:10.072: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule Jun 30 13:06:10.072: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> TclModule_313DD624_0_687505696 Jun 30 13:06:10.072: //4110//AFW_:/AFW_M_TclModule_Action: Jun 30 13:06:10.072: //4110//AFW_:/AFW_TclModule_DefaultEvHandling: Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Leg_CheckIncomingCallBlock: Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Leg_SettlementValidateCall: target=ipv4:172.17.254.6, tokenp=0x0 Jun 30 13:06:10.072: //4110/CD63A95A81EC/AFW_:/AFW_Leg_IncomingTranslate: Jun 30 13:06:10.072: //4110//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALL_INIT[1],ev_setup_indication[31])---[act_Setup]------ Jun 30 13:06:10.072: //4110//TCL :/tcl_LegObjCmd: leg setupack leg_incoming Jun 30 13:06:10.072: //4110//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming Jun 30 13:06:10.072: //4110//AFW_:/vtd_lg_incoming: argc 2 Jun 30 13:06:10.072: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.072: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.072: //4110//TCL :/tcl_LegObjCmd: leg proceeding leg_incoming Jun 30 13:06:10.072: //4110//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming Jun 30 13:06:10.072: //4110//AFW_:/vtd_lg_incoming: argc 2 Jun 30 13:06:10.072: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.072: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.076: //4110//TCL :/tcl_LegObjCmd: leg connect leg_incoming Jun 30 13:06:10.076: //4110//TCL :/tcl_LegConnectObjCmd: connect leg_incoming Jun 30 13:06:10.076: //4110//AFW_:/vtd_lg_incoming: argc 2 Jun 30 13:06:10.076: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.076: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.076: //4110/CD63A95A81EC/AFW_:/AFW_Leg_Connect: prog_ind=0, ccRawMsgInfo_t=0x32507134, cData=0 Jun 30 13:06:10.076: //-1//SSIN:/AFW_SS_H450_PrepareCommonInfo: Leg peer_tag=10 Jun 30 13:06:10.076: //-1//SSIN:/AFW_SS_H450_PrepareCIInform: Jun 30 13:06:10.076: //4110/CD63A95A81EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 842 type 1 Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagObjCmd: infotag get leg_ani Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani Jun 30 13:06:10.076: //4110//AFW_:/vtr_lg_ani: argc 2 argindex 2 Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagObjCmd: infotag get leg_dnis Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis Jun 30 13:06:10.076: //4110//AFW_:/vtr_lg_dnis: argc 2 argindex 2 Jun 30 13:06:10.076: //4110//TCL :/tcl_AAAObjCmd: aaa authenticate 7134224200 7134221000 Jun 30 13:06:10.076: //4110//TCL :/tcl_AuthenticateObjCmd: authenticate 7134224200 7134221000 Jun 30 13:06:10.076: //4110//TCL :/tcl_AuthenticateObjCmd: account=7134224200, password=7134221000, methodList=, av-send= Jun 30 13:06:10.076: //-1//AFW_:/AFW_Event_New: Event ID: ev_authenticate_done Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 2 Jun 30 13:06:10.076: //-1//VAAA:0/voip_start_authentication: name:7134224200, service:ivr tcl authentication, method: Jun 30 13:06:10.076: //-1//VAAA:0/voip_alloc_aaa_uid: Jun 30 13:06:10.076: //-1//VAAA:0/voip_start_authentication: UID=2506 Jun 30 13:06:10.076: voip_aaa_get_method_index(0): ERROR: method "h323" not defined. Jun 30 13:06:10.076: //-1//VAAA:0/voip_start_authentication: No authen list Jun 30 13:06:10.076: //-1//VAAA:0/voip_set_release_source: src[8]
Jun 30 13:06:10.076: //4110//TCL :/tcl_AuthenticateObjCmd: Start authenticate failed Jun 30 13:06:10.076: //4110//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_DecrNPendingCmd: PendingCmdCount: 1 Jun 30 13:06:10.076: //4110//AFW_:/AFW_FSM_Drive: ACTION END: -------------(AUTHENTICATE[10])--------------- Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> TclModule_313DD624_0_687505696 Jun 30 13:06:10.076: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30007040, Type: Event, RefCount: 0 Jun 30 13:06:10.076: //4110/CD63A95A81EC/AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FB40, Type: DataList, RefCount: 0 Jun 30 13:06:10.076: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1 Jun 30 13:06:10.076: //4110//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED Jun 30 13:06:10.076: //4110//AFW_:/AFW_Process_GetAppQEvent: Received Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: Event[APP_EV_AUTHENTICATE_DONE(174)] { Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: EXECENV[0x31D29988] Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: LEG[4110][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: ) Jun 30 13:06:10.076: //-1//AFW_:/AFW_Process_GetAppQEvent: } Jun 30 13:06:10.076: //4110//AFW_:/AFW_M_TclModule_EventPreProcess: Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_313DD624_0_687505696 Jun 30 13:06:10.076: //4110//AFW_:/AFW_M_TclModule_Action: Jun 30 13:06:10.076: //4110//AFW_:/AFW_TclModule_DefaultEvHandling: Jun 30 13:06:10.076: //4110//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(AUTHENTICATE[10],ev_authenticate_done[174])---[act_Authenticated]------ Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 30 13:06:10.076: //4110//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 30 13:06:10.076: //4110//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 30 13:06:10.076: //4110//TCL :/tcl_PutsObjCmd: @@@@status=au_001 Jun 30 13:06:10.076: Jun 30 13:06:10.076: //4110//TCL :/tcl_LegObjCmd: leg setup 7134221000 callInfo leg_incoming Jun 30 13:06:10.076: //4110//CSPK:/tcl_LegSetupObjCmd: leg setup 7134221000 callInfo leg_incoming Jun 30 13:06:10.076: //4110//AFW_:/vtd_lg_incoming: argc 4 Jun 30 13:06:10.076: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.076: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.076: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not found for tag(56) Jun 30 13:06:10.076: //-1//AFW_:/AFW_ExecEnv_CallProc: CallSetup::Start Jun 30 13:06:10.076: //4110//CSPK:/C_CallSetup_Start: ControlInfo = 0x31BB6234, callInfo = 0x31D3EEDC, destination[0]=7134221000 Jun 30 13:06:10.076: //4110//PACK:/ParamRead: Reading param mode from callsetup Jun 30 13:06:10.076: //-1//PACK:/ParamRead: Reading parameter mode for a script callsetup, Jun 30 13:06:10.076: //-1//PACK:/ParamRead: appRegParams=0x313C9104 dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 30 13:06:10.076: //-1//PACK:/ParamRead: service level: script callsetup, Jun 30 13:06:10.076: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 30 13:06:10.076: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param callsetup.mode Jun 30 13:06:10.076: //-1//PACK:/ParamRead_ElementGetWithGroup: Param callsetup.mode was not found in this container Jun 30 13:06:10.076: //-1//PACK:/ParamRead: Parameter for the script: callsetup has been read: mode Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataString_Get: Jun 30 13:06:10.076: //4110//CSPK:/C_CallSetup_Start: configured mode=rotary (1) Jun 30 13:06:10.076: //4110//PACK:/ParamRead: Reading param reroutemode from callsetup Jun 30 13:06:10.076: //-1//PACK:/ParamRead: Reading parameter reroutemode for a script callsetup, Jun 30 13:06:10.076: //-1//PACK:/ParamRead: appRegParams=0x313C9104 dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 30 13:06:10.076: //-1//PACK:/ParamRead: service level: script callsetup, Jun 30 13:06:10.076: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 30 13:06:10.076: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param callsetup.reroutemode Jun 30 13:06:10.076: //-1//PACK:/ParamRead_ElementGetWithGroup: Param callsetup.reroutemode was not found in this container Jun 30 13:06:10.076: //-1//PACK:/ParamRead: Parameter for the script: callsetup has been read: reroutemode Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataString_Get: Jun 30 13:06:10.076: //4110//CSPK:/C_CallSetup_Start: configured reroutemode=rotary (1) Jun 30 13:06:10.076: //-1//Call:/AFW_CallSetup_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: CallSetup(Size=4688) Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataArray_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 30 13:06:10.076: //-1//AFW_:/AFW_FSM_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: FSM(Size=104) Jun 30 13:06:10.076: //-1//AFW_:LP:EE31D29988000:HN28FA8124:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1 Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 2 Jun 30 13:06:10.076: //4110//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener Jun 30 13:06:10.076: //4110//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_2A696210_0_687505700 Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: CallSetup_2A696210_0_687505700, type: CallSetup Jun 30 13:06:10.076: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x2A696210, Type: CallSetup, RefCount: 2 Jun 30 13:06:10.076: //4110//Call:/AFW_CallSetup_AddDest: 7134221000 index 0 Jun 30 13:06:10.076: //4110//Call:/AFW_CallSetup_SetIntWrkLeg: Jun 30 13:06:10.076: //4110/CD63A95A81EC/AFW_:/AFW_Leg_SignalPeerGet: Leg [4110] Jun 30 13:06:10.076: //-1//AFW_:/AFW_ExecEnv_CallProc: Session::GetSigPeer Jun 30 13:06:10.076: //-1//AFW_:/C_PackageSession_GetSigPeer: Jun 30 13:06:10.076: //4110/CD63A95A81EC/AFW_:/C_PackageSession_GetSigPeer: No Interworking module on Leg, no signal peer Jun 30 13:06:10.076: //4110//Call:/AFW_M_CallSetup_Initiate: Jun 30 13:06:10.076: //4110//Call:/CS_UpdateMLPPInfo: MLPP info not available and hence not updated Jun 30 13:06:10.076: //4110//Call:/CallSetupInitiate: Jun 30 13:06:10.076: //4110//Call:/CS_Placecall: Jun 30 13:06:10.076: //4110//Call:/CS_UpdateMLPPInfo: MLPP info not available and hence not updated Jun 30 13:06:10.076: //-1//Dest:/AFW_Destination_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Destination(Size=11816) Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataArray_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataArray(Size=80) Jun 30 13:06:10.076: //-1//AFW_:/AFW_FSM_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: FSM(Size=104) Jun 30 13:06:10.076: //-1//AFW_:/AFW_FSM_New: Jun 30 13:06:10.076: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: FSM(Size=104) Jun 30 13:06:10.076: //-1//AFW_:LP:EE31D29988000:HN28FA8124:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 2 Jun 30 13:06:10.076: //4110//AFW_:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 3 Jun 30 13:06:10.076: //4110//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener Jun 30 13:06:10.076: //4110//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_31C3DFF4_0_687505700 Jun 30 13:06:10.076: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: Destination_31C3DFF4_0_687505700, type: Destination Jun 30 13:06:10.076: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C3DFF4, Type: Destination, RefCount: 2 Jun 30 13:06:10.076: //4110//Dest:/AFW_Destination_AddDest: Jun 30 13:06:10.080: //-1//Dest:/AFW_Destination_AddDest: adding destination "7134221000" Jun 30 13:06:10.080: //4110//Dest:/AFW_Destination_SetIntWrkLeg: LEG[4110 ][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:10.080: //4110//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg Jun 30 13:06:10.080: //4110//Dest:/DestSetIntWrkLeg: Jun 30 13:06:10.080: //4110/CD63A95A81EC/AFW_:/AFW_Object_AddListener: adding Module Destination as listener Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: LEG_4110, type: Leg Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 3 Jun 30 13:06:10.080: //4110//Dest:/AFW_M_Destination_Initiate: Jun 30 13:06:10.080: //-1//VAAA:0/voip_rot_acct_supp_enabled: Rotary suppress disabled Jun 30 13:06:10.080: //-1//AFW_:/AFW_Util_SaveRawMsg: Jun 30 13:06:10.080: //4110//Dest:/AFW_M_Destination_Initiate: Outgoing guid : CD63A95A.A25011E0.81EC9A67.0DD4F946 Jun 30 13:06:10.080: Incoming_guid : 00000000.00000000.00000000.00000000 Jun 30 13:06:10.080: //4110//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : 00000000.00000000.00000000.00000000 Jun 30 13:06:10.080: Incoming_gcid : 00000000.00000000.00000000.00000000 Jun 30 13:06:10.080: //4110//Dest:/DestUpdateMLPPInfo: MLPP Information not available and hence not updated Jun 30 13:06:10.080: //4110//Dest:/DestSetupInitiate: Jun 30 13:06:10.080: //4110//Dest:/DestAddRerouteSetupInfo: Jun 30 13:06:10.080: //4110//Dest:/DestAddTransferSetupInfo: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 7134221000
Jun 30 13:06:10.080: //4110//PACK:/ParamRead: Reading param after-hours-exempt from callsetup Jun 30 13:06:10.080: //-1//PACK:/ParamRead: Reading parameter after-hours-exempt for a script callsetup, Jun 30 13:06:10.080: //-1//PACK:/ParamRead: appRegParams=0x313C9104 dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 30 13:06:10.080: //-1//PACK:/ParamRead: service level: script callsetup, Jun 30 13:06:10.080: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 30 13:06:10.080: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param callsetup.after-hours-exempt Jun 30 13:06:10.080: //-1//PACK:/ParamRead_ElementGetWithGroup: Param callsetup.after-hours-exempt was not found in this container Jun 30 13:06:10.080: //-1//PACK:/ParamRead: Parameter for the script: callsetup has been read: after-hours-exempt Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataBoolean_Get: Jun 30 13:06:10.080: //4110//Dest:/DestMatchDialPeer: Jun 30 13:06:10.080: //4110//Dest:/DestMatchDialPeer: src carrier id:, tgt carrier id: Jun 30 13:06:10.080: //4110//Dest:/DestQueuePeers: Matched peers: Jun 30 13:06:10.080: //4110//Dest:/DestPeerItemUpdatePreemptInfo: Jun 30 13:06:10.080: //-1//Dest:/DestQueuePeers: 100 Jun 30 13:06:10.080: //-1//Dest:/DestQueuePeers: , Total(1) Jun 30 13:06:10.080: //4110//Dest:/DestDialPeerRotary: Jun 30 13:06:10.080: //4110//Dest:/DestOutboundCallUsingPeer: dest(7134221000), numexpDest(7134221000), numDestDigits(0) Jun 30 13:06:10.080: //4110//Dest:/DestOutboundCallUsingPeer: prefix(), peer tag(100) Jun 30 13:06:10.080: //4110//Dest:/DestUpdatePreemptSetupInfo: Jun 30 13:06:10.080: //4110//OSP :/Dest_Settlement_MatrixCheck: retcode=2 cid(4110) trans=0x0, provider=0 User is not authenticated and not roaming Jun 30 13:06:10.080: %VOICE_IEC-3-GW: C SCRIPTS: Internal Error (OSP Fail): IEC=1.1.228.11.32.0 on callID 4110 GUID=CD63A95AA25011E081EC9A670DD4F946 Jun 30 13:06:10.080: //4110//Dest:/DestSetupInitiate: Dial peer rotary failed Jun 30 13:06:10.080: //4110//Dest:/DestSetupInitiate: Jun 30 13:06:10.080: : before setting failure to featvsa Jun 30 13:06:10.080: //-1//Dest:/DestSetFailureToFeatureVsa: Jun 30 13:06:10.080: Inside FailureFun. callid is 4110,fname is 0, -1 Jun 30 13:06:10.080: //-1//Dest:/DestSetFailureToFeatureVsa: Jun 30 13:06:10.080: Feature vsa is 301B6268, feature res = 1 Jun 30 13:06:10.080: //-1//Dest:/DestSetFailureToFeatureVsa: Jun 30 13:06:10.080: //4110//Dest:/DestSetupInitiate: Jun 30 13:06:10.080: : after setting failure to featvsa Jun 30 13:06:10.080: //4110//Dest:/DestResetCallInfo: Jun 30 13:06:10.080: //4110//Dest:/DestComplete: peer #:100 IW State IW_STATE_INIT, OB State OB_STATE_INIT Jun 30 13:06:10.080: //-1//Dest:/DestStatusFromDiscCause: mapped "no route to destination (3)"(3) to DEST_NO_RESOURCE(3) Jun 30 13:06:10.080: //4110//Dest:/DestUpdateMLPPCause: status=3, cause=3 Jun 30 13:06:10.080: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_ReturnArgEv: Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x31C39E90 Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 4 Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x300EBBD0, with Instance = 0x31C39E90 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[4110 ][LEG_INCCONNECTED(5)][Cause(0)]} Jun 30 13:06:10.080: //4110/CD63A95A81EC/AFW_:/AFW_Object_RemoveListener: Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementDelete: param name LEG_4110 Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 3 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_UnListen: NumObjects: 0 Jun 30 13:06:10.080: //4110//Dest:/DestReturn: Destination Returning(ds_003 Status DEST_NO_RESOURCE) Jun 30 13:06:10.080: //4110//Call:/CS_Placecall: Call placed to 7134221000 index 0 Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataString_New: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataString(Size=20) Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementSetNameSpace: Adding param space Session, name LastCmdHandle, entryKey LastCmdHandle.Session, type DataString Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: LastCmdHandle.Session, type: DataString Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x2A658E3C, Type: DataString, RefCount: 2 Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A658E3C, Type: DataString, RefCount: 1 Jun 30 13:06:10.080: //4110//TCL :/tcl_FSMObjCmd: fsm setstate PLACECALL Jun 30 13:06:10.080: //4110//TCL :/tcl_FSMSetStateObjCmd: setstate setstate PLACECALL Jun 30 13:06:10.080: //4110//AFW_:/AFW_FSM_Drive: ACTION END: -------------(PLACECALL[9])--------------- Jun 30 13:06:10.080: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> NULL Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30007A70, Type: Event, RefCount: 0 Jun 30 13:06:10.080: //4110//AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FBB8, Type: DataList, RefCount: 0 Jun 30 13:06:10.080: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.080: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED Jun 30 13:06:10.080: //4110//AFW_:/AFW_Process_GetPriorityQEvent: Received Jun 30 13:06:10.080: //-1//AFW_:/AFW_Process_GetPriorityQEvent: Event[APP_EV_DESTINATION_DONE(203)] { Jun 30 13:06:10.080: //-1//AFW_:/AFW_Process_GetPriorityQEvent: EXECENV[0x31D29988] Jun 30 13:06:10.080: //-1//AFW_:/AFW_Process_GetPriorityQEvent: MOD[Destination_31C3DFF4_0_687505700] ( Jun 30 13:06:10.080: //-1//AFW_:/AFW_Process_GetPriorityQEvent: ) Jun 30 13:06:10.080: //-1//AFW_:/AFW_Process_GetPriorityQEvent: } Jun 30 13:06:10.080: //4110//Dest:/AFW_M_Destination_EventPreProcess: Jun 30 13:06:10.080: //4110//AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:10.080: //4110//AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:10.080: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[CallSetup_2A696210_0_687505700] ( Jun 30 13:06:10.080: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[Destination_31C3DFF4_0_687505700] ( Jun 30 13:06:10.080: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:10.080: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:10.080: //4110//AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:10.080: //4110//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x300EBBD0, with Instance = 0x31C39E90 Jun 30 13:06:10.080: //4110/CD63A95A81EC/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementSet: Adding param: LEG_4110, type: Leg Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 4 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Object_RemoveListener: Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementDelete: param name Destination_31C3DFF4_0_687505700 Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C3DFF4, Type: Destination, RefCount: 1 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_UnListen: NumObjects: 1 Jun 30 13:06:10.080: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_2A696210_0_687505700 Jun 30 13:06:10.080: //4110//Call:/AFW_M_CallSetup_Action: Jun 30 13:06:10.080: //4110//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[203])---[C_Action]------ Jun 30 13:06:10.080: //4110//Call:/CS_Placecall_DestDone: Jun 30 13:06:10.080: //4110//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])--------------- Jun 30 13:06:10.080: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_ReturnArgEv: Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x31C39E90 Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 5 Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x3006A98C, with Instance = 0x31C39E90 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[4110 ][LEG_INCCONNECTED(5)][Cause(0)]} Jun 30 13:06:10.080: //4110/CD63A95A81EC/AFW_:/AFW_Object_RemoveListener: Jun 30 13:06:10.080: //-1//AFW_:/AFW_DataArray_ElementDelete: param name LEG_4110 Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 4 Jun 30 13:06:10.080: //4110//AFW_:/AFW_Module_UnListen: NumObjects: 0 Jun 30 13:06:10.080: //4110//Call:/CS_Complete: CallSetup Returning(ls_003 Status CS_NO_RESOURCE) Jun 30 13:06:10.080: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_2A696210_0_687505700 ---> NULL Jun 30 13:06:10.080: //4110//AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:10.080: //4110//AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:10.080: //4110//AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:10.080: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30004780, Type: Event, RefCount: 0 Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Event_Free: MODULEDONEEVENT for a Module: Destination_31C3DFF4_0_687505700 Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_RemoveAllListener: Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 3 Jun 30 13:06:10.084: //4110//AFW_:/AFW_ExecEnv_DecrNPendingCmd: PendingCmdCount: 2 Jun 30 13:06:10.084: //-1//AFW_:HN28FA8124:/AFW_M_Event_Free: ExecEnv objCount: 3 Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C3DFF4, Type: Destination, RefCount: 0 Jun 30 13:06:10.084: //-1//Dest:HN28FA8124:/AFW_M_Destination_Free: Jun 30 13:06:10.084: //-1//Dest:HN28FA8124:/DestEmptyPreemptHoldQ: Jun 30 13:06:10.084: //-1//OSP :HN28FA8124:/Dest_Settlement_Cleanup: cid(4110) trans=0x0, provider=0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A61C61C, Type: FSM, RefCount: 0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_FSM_Free: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x301057A0, Type: FSM, RefCount: 0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_FSM_Free: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A639380, Type: DataArray, RefCount: 0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FA50, Type: DataList, RefCount: 0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 3 Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8F988, Type: DataList, RefCount: 0 Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.084: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2 Jun 30 13:06:10.084: //4110//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED Jun 30 13:06:10.084: //4110//AFW_:/AFW_Process_GetPriorityQEvent: Received Jun 30 13:06:10.084: //-1//AFW_:/AFW_Process_GetPriorityQEvent: Event[APP_EV_CALLSETUP_DONE(201)] { Jun 30 13:06:10.084: //-1//AFW_:/AFW_Process_GetPriorityQEvent: EXECENV[0x31D29988] Jun 30 13:06:10.084: //-1//AFW_:/AFW_Process_GetPriorityQEvent: MOD[CallSetup_2A696210_0_687505700] ( Jun 30 13:06:10.084: //-1//AFW_:/AFW_Process_GetPriorityQEvent: ) Jun 30 13:06:10.084: //-1//AFW_:/AFW_Process_GetPriorityQEvent: } Jun 30 13:06:10.084: //4110//Call:/AFW_M_CallSetup_EventPreProcess: Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[4110][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[CallSetup_2A696210_0_687505700] ( Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_GetFirst: Elem = 0x3006A98C, with Instance = 0x31C39E90 Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_RemoveListener: Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataArray_ElementDelete: param name CallSetup_2A696210_0_687505700 Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A696210, Type: CallSetup, RefCount: 1 Jun 30 13:06:10.084: //4110//AFW_:/AFW_Module_UnListen: NumObjects: 1 Jun 30 13:06:10.084: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_313DD624_0_687505696 Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_TclModule_Action: Jun 30 13:06:10.084: //4110//AFW_:/AFW_TclModule_DefaultEvHandling: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:10.084: //4110//PACK:/ParamRead: Reading param med-inact-det from callfeature Jun 30 13:06:10.084: //-1//PACK:/ParamRead: Reading parameter med-inact-det for a script callfeature, Jun 30 13:06:10.084: //-1//PACK:/ParamRead: appRegParams=0x312AE2FC dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 30 13:06:10.084: //-1//PACK:/ParamRead: service level: script callfeature, Jun 30 13:06:10.084: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 30 13:06:10.084: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param callfeature.med-inact-det Jun 30 13:06:10.084: //-1//PACK:/ParamRead_ElementGetWithGroup: Param callfeature.med-inact-det was not found in this container Jun 30 13:06:10.084: //-1//PACK:/ParamRead: Parameter for the script: callfeature has been read: med-inact-det Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataString_Get: Jun 30 13:06:10.084: //4110//PACK:/ParamRead: Reading param long-dur-call-mon from callfeature Jun 30 13:06:10.084: //-1//PACK:/ParamRead: Reading parameter long-dur-call-mon for a script callfeature, Jun 30 13:06:10.084: //-1//PACK:/ParamRead: appRegParams=0x312AE2FC dpParamArray=0x0 pMainParamArray=0x31CE4834 Jun 30 13:06:10.084: //-1//PACK:/ParamRead: service level: script callfeature, Jun 30 13:06:10.084: //-1//PACK:/ParamRead: pMainParamArray=0x31CE4834 pMainGroupList=0x0 Jun 30 13:06:10.084: //-1//PACK:/ParamRead_ElementGetWithGroup: Looking for param callfeature.long-dur-call-mon Jun 30 13:06:10.084: //-1//PACK:/ParamRead_ElementGetWithGroup: Param callfeature.long-dur-call-mon was not found in this container Jun 30 13:06:10.084: //-1//PACK:/ParamRead: Parameter for the script: callfeature has been read: long-dur-call-mon Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataString_Get: Jun 30 13:06:10.084: //4110//AFW_:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [4110]'s session Jun 30 13:06:10.084: //-1//AFW_:/AFW_ExecEnv_CallProc: Session::SetMask Jun 30 13:06:10.084: //4110//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(PLACECALL[9],ev_setup_done[201])---[act_CallSetupDone]------ Jun 30 13:06:10.084: //4110//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 30 13:06:10.084: //4110//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 30 13:06:10.084: //4110//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 30 13:06:10.084: //4110//TCL :/tcl_InfotagObjCmd: infotag get evt_status Jun 30 13:06:10.084: //4110//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status Jun 30 13:06:10.084: //4110//AFW_:/vtr_ev_status: argc 2 argindex 2 Jun 30 13:06:10.084: //4110//TCL :/tcl_PlayToneObjCmd: playtone leg_incoming ls_003 Jun 30 13:06:10.084: //4110//AFW_:/vtd_lg_incoming: argc 3 Jun 30 13:06:10.084: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.084: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Leg_GenerateTone: ccTone 512 cptone 2 Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Leg_GetCodec: Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Leg_GetCodec: Jun 30 13:06:10.084: AFW_Leg_GetCodec Using Voice Class Codec, tag = 2
Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Leg_GenerateToneVOIP: callID 4110 ccTone 512 cptone 2 Jun 30 13:06:10.084: get_cp_tone_buffer get G729 tone 2 length 500 at 2A08EF64 Jun 30 13:06:10.084: //4110//MSW :/msw_create: cbf=0x24BA2570 Jun 30 13:06:10.084: //-1//MSM :MS23:/ms_create: Iniz ply_timer Jun 30 13:06:10.084: //4110//MSW :/msw_synth_open: mediaStream 0x300682A8 created Jun 30 13:06:10.084: //4110//MSW :/msw_synth_open: rtspStream 0x29B9366C created, status=RTSP_STATUS_SUCCESS, session_id=0x17 (23) Jun 30 13:06:10.084: //4110//MSW :/msw_synth_open: AIS : Creating TTS AIS Backend record Jun 30 13:06:10.084: //-1//MSM :MS24:/ms_create: Iniz ply_timer Jun 30 13:06:10.084: //4110//MSW :/msw_recrd_open: Jun 30 13:06:10.084: :msw_recrd_open mediaStream 0x31CEA83C created Jun 30 13:06:10.084: //4110//MSW :/msw_recrd_open: rtspStream 0x29B93674 created, status=RTSP_STATUS_SUCCESS, session_id=0x18 (24) Jun 30 13:06:10.084: //4110//MSW :/msw_recog_open: AIS : Creating ASR AIS Backend record Jun 30 13:06:10.084: //-1//MSW :/msw_associate_call: Jun 30 13:06:10.084: msw_associate_call: callID=0x100E(4110), genericStream=0x296DDDD8 Jun 30 13:06:10.084: //-1//MCM :MC6:/mc_waitq_unlink: elm=2A64E19C Jun 30 13:06:10.084: //-1//MCM :MC6:/mc_waitq_unlink: prompt_wait=0 prompt_active=0
Jun 30 13:06:10.084: //-1//MCM :MC6:/mc_waitq_delete: prompt_wait=0 prompt_active=1F4 Jun 30 13:06:10.084: //4110/CD63A95A81EC/AFW_:/AFW_Leg_GenerateToneVOIP: ccTone 512 cptone 2 msw_synth_start for tone://US_g729_tone_congestion codec 16 (req 16) g729 Jun 30 13:06:10.084: //-1//MSW :/msw_synth_start: Jun 30 13:06:10.084: msw_synth_start: Enter... Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x313DD624 Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_Enqueue: Trying to add element to a list Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x313DD624 Jun 30 13:06:10.084: //-1//AFW_:/AFW_DataList_Enqueue: Adding element: Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x313DD624, Type: TclModule, RefCount: 3 Jun 30 13:06:10.084: //4110//MSW :/msw_synth_start: current_stream_id=1, content 0x2A0FC948, dynamicS 0x0, current_state=MSW_S_IDLE Jun 30 13:06:10.084: //4110//MSW :/msu_synth_partial_play: Media Stream URL Jun 30 13:06:10.084: //4110//MSM :/ms_play: Converting static to dynamic prompting Jun 30 13:06:10.084: //-1//DPM :LPP14:MC6:/dp_mc_cnvtDynamicS: convert static prompt OK Jun 30 13:06:10.084: //-1//MCM :MR13:/mc_createDynamicReader: Jun 30 13:06:10.084: //4110//MSM :/ms_get_packet_size: Jun 30 13:06:10.084: ms_get_packet_size Using Voice Class Codec, tag = 2
Jun 30 13:06:10.084: //4110//MSM :/ms_associate: packet_size = 40 timestamp increment = 320 packet_duration = 40 Coder = 16 vad = 0 SampleRate = 8000 Jun 30 13:06:10.084: //4110//MSM :/ms_associate: >>ccAssociateStream() Jun 30 13:06:10.084: //4110//TCL :/tcl_TimerObjCmd: timer start leg_timer 5 leg_incoming Jun 30 13:06:10.084: //4110//TCL :/tcl_TimerStartObjCmd: timer start leg_timer 5 leg_incoming Jun 30 13:06:10.084: //4110//AFW_:/vtd_lg_incoming: argc 4 Jun 30 13:06:10.084: //4110//AFW_:/vtd_lg_incoming: Legs [4110 ] Jun 30 13:06:10.084: //4110//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1 Jun 30 13:06:10.084: //4110//TCL :/tcl_FSMObjCmd: fsm setstate CALLDISCONNECT Jun 30 13:06:10.084: //4110//TCL :/tcl_FSMSetStateObjCmd: setstate setstate CALLDISCONNECT Jun 30 13:06:10.084: //4110//AFW_:/AFW_FSM_Drive: ACTION END: -------------(CALLDISCONNECT[4])--------------- Jun 30 13:06:10.084: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> NULL Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:10.084: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x300084A0, Type: Event, RefCount: 0 Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.084: //4110//AFW_:/AFW_M_Event_Free: MODULEDONEEVENT for a Module: CallSetup_2A696210_0_687505700 Jun 30 13:06:10.084: //4110//AFW_:/AFW_Object_RemoveAllListener: Jun 30 13:06:10.084: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 2, CmdPending 2 Jun 30 13:06:10.088: //4110//AFW_:/AFW_ExecEnv_DecrNPendingCmd: PendingCmdCount: 1 Jun 30 13:06:10.088: //-1//AFW_:HN28FA8124:/AFW_M_Event_Free: ExecEnv objCount: 2 Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A696210, Type: CallSetup, RefCount: 0 Jun 30 13:06:10.088: //-1//Call:HN28FA8124:/AFW_M_CallSetup_Free: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A61C95C, Type: FSM, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_FSM_Free: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A618114, Type: DataArray, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30060010, Type: DataList, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 2 Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FAA0, Type: DataList, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.088: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1 Jun 30 13:06:10.088: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:10.088: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.088: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30009900, Type: Event, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FC30, Type: DataList, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.088: //4110/CD63A95A81EC/VAAA:0/voip_connect_ccapi_accounting: error: Bad acct_db Jun 30 13:06:10.088: //4110//MSM :LP:MS23:/ms_associateDone: Jun 30 13:06:10.088: //4110//MSM :/ms_asDone_buginf: callID=0x100E, pVdb=0x29C689FC, disposition=0, playFunc=0x24F98C18, codec=0x10=g729r8, vad=0, mediaType=1, streamAssocID=4111 Jun 30 13:06:10.088: //4110//MSM :/ms_associateDone: Setting initial seqnum=6702 for the call Jun 30 13:06:10.088: //-1//MCM :MR13:/mc_setup_reader_encaps: SSRC: 0xFFFFFFFF SeqNum: 0x1A2E Jun 30 13:06:10.088: //4110//MSM :/ms_associateDone: First Buf Play at 1w0d of tone://US_g729_tone_congestion Jun 30 13:06:10.088: //4110//MSM :/ms_associateDone: 1w0d, Tstart(ply: iSndDly 0) Jun 30 13:06:10.088: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:10.088: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:10.088: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x3000A330, Type: Event, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_Event_Free: Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL Jun 30 13:06:10.088: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FC80, Type: DataList, RefCount: 0 Jun 30 13:06:10.088: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:10.868: //-1//MCM :MR13:/mc_make_packets_DQ: mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 500 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 40 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 460 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 80 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 420 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 120 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 380 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 160 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 340 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 200 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 300 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 240 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 260 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 280 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 220 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 320 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 180 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 360 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 140 Jun 30 13:06:10.868: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 400 Jun 30 13:06:10.872: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 100 Jun 30 13:06:10.872: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 440 Jun 30 13:06:10.872: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 60 Jun 30 13:06:10.872: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 480 Jun 30 13:06:10.872: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 20 Jun 30 13:06:10.872: //-1//MCM :MR13:/mc_make_packets_DQ: mc_fill_pakList(): status_fillpak 0, / mcr->thisMcBytesPlay 480, mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:10.872: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:10.872: //-1//MCM :MR13:/mc_make_packets_DQ: No more prompts to play: Jun 30 13:06:10.872: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:10.872: //4110//MSM :/ms_handle_stream_timer: >>ms_start_play() Jun 30 13:06:10.872: //4110//MSM :/ms_start_play: 1w0d mgdTstart(rf) Jun 30 13:06:10.872: //4110//MSM :/ms_start_play: 1w0d mgdTstop(ply) Jun 30 13:06:10.916: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:10.956: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:10.996: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:11.036: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:11.292: //-1//MCM :/mc_make_packets_DQ: No more on reader Jun 30 13:06:11.292: //4110//MSM :/ms_need_packets_more: mgdTstart(rf) at 1w0d Jun 30 13:06:11.296: //4110//MSM :/ms_play_part: sent: 200, numInBuf: 1220 lastFill: 1420, numBytes: 220 Jun 30 13:06:11.336: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1380 lastFill: 1420, numBytes: 40 Jun 30 13:06:11.376: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1380 lastFill: 1420, numBytes: 40 Jun 30 13:06:11.376: //4110//MSM :/ms_process: $w$ intEvent MS_E_STOP_PLAY Jun 30 13:06:11.376: //4110//MSM :/ms_stop_play: mgdTstop at 1w0d (cause MS_STOP_COMPLETE) Jun 30 13:06:11.376: //4110//MSM :/ms_stop_play: mgdTstop(rf) at 1w0d Jun 30 13:06:11.376: //4110//MSM :/ms_restart_prompt: Restarting the prompt for > 1 repetions..as it got cutoff Jun 30 13:06:11.376: //4110//MSM :/ms_cutoff: 1w0d Tstop Jun 30 13:06:11.376: //4110//MSM :/ms_cutoff: play cutoff at 1w0d Jun 30 13:06:11.376: //-1//MCM :MR13:/mc_make_packets_DQ: mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 500 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 40 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 460 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 80 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 420 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 120 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 380 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 160 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 340 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 200 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 300 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 240 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 260 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 280 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 220 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 320 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 180 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 360 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 140 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 400 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 100 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 440 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 60 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 480 Jun 30 13:06:11.376: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 20 Jun 30 13:06:11.376: //-1//MCM :MR13:/mc_make_packets_DQ: mc_fill_pakList(): status_fillpak 0, / mcr->thisMcBytesPlay 480, mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:11.376: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:11.376: //-1//MCM :MR13:/mc_make_packets_DQ: No more prompts to play: Jun 30 13:06:11.376: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:11.376: //4110//MSM :/ms_cutoff: First Buf Play at 1w0d of tone://US_g729_tone_congestion Jun 30 13:06:11.376: //4110//MSM :/ms_cutoff: ms_cutoff() 1w0d, Tstart(iSndDly 0) Jun 30 13:06:11.376: //4110//MSM :/ms_process: >>ms_delete_event(MS_E_int) Jun 30 13:06:12.204: //4110//MSM :/ms_handle_stream_timer: >>ms_start_play() Jun 30 13:06:12.204: //4110//MSM :/ms_start_play: 1w0d mgdTstart(rf) Jun 30 13:06:12.204: //4110//MSM :/ms_start_play: 1w0d mgdTstop(ply) Jun 30 13:06:12.248: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:12.288: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:12.328: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:12.368: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:12.916: //-1//MCM :/mc_make_packets_DQ: No more on reader Jun 30 13:06:12.916: //4110//MSM :/ms_need_packets_more: mgdTstart(rf) at 1w0d Jun 30 13:06:12.920: //4110//MSM :/ms_play_part: sent: 320, numInBuf: 928 lastFill: 1248, numBytes: 512 Jun 30 13:06:12.920: //4110//MSM :/ms_process: $w$ intEvent MS_E_STOP_PLAY Jun 30 13:06:12.920: //4110//MSM :/ms_stop_play: mgdTstop at 1w0d (cause MS_STOP_COMPLETE) Jun 30 13:06:12.920: //4110//MSM :/ms_stop_play: mgdTstop(rf) at 1w0d Jun 30 13:06:12.920: //4110//MSM :/ms_restart_prompt: Restarting the prompt for > 1 repetions..as it got cutoff Jun 30 13:06:12.920: //4110//MSM :/ms_cutoff: 1w0d Tstop Jun 30 13:06:12.920: //4110//MSM :/ms_cutoff: play cutoff at 1w0d Jun 30 13:06:12.920: //-1//MCM :MR13:/mc_make_packets_DQ: mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 500 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 40 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 460 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 80 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 420 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 120 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 380 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 160 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 340 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 200 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 300 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 240 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 260 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 280 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 220 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 320 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 180 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 360 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 140 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 400 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 100 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 440 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 60 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 480 Jun 30 13:06:12.920: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 20 Jun 30 13:06:12.920: //-1//MCM :MR13:/mc_make_packets_DQ: mc_fill_pakList(): status_fillpak 0, / mcr->thisMcBytesPlay 480, mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:12.920: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:12.920: //-1//MCM :MR13:/mc_make_packets_DQ: No more prompts to play: Jun 30 13:06:12.920: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:12.920: //4110//MSM :/ms_cutoff: First Buf Play at 1w0d of tone://US_g729_tone_congestion Jun 30 13:06:12.920: //4110//MSM :/ms_cutoff: ms_cutoff() 1w0d, Tstart(iSndDly 0) Jun 30 13:06:12.920: //4110//MSM :/ms_process: >>ms_delete_event(MS_E_int) Jun 30 13:06:13.752: //4110//MSM :/ms_handle_stream_timer: >>ms_start_play() Jun 30 13:06:13.752: //4110//MSM :/ms_start_play: 1w0d mgdTstart(rf) Jun 30 13:06:13.752: //4110//MSM :/ms_start_play: 1w0d mgdTstop(ply) Jun 30 13:06:13.796: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:13.836: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:13.876: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:13.916: //4110//MSM :/ms_play_part: sent: 40, numInBuf: 1400 lastFill: 1440, numBytes: 40 Jun 30 13:06:14.408: //-1//MCM :/mc_make_packets_DQ: No more on reader Jun 30 13:06:14.408: //4110//MSM :/ms_need_packets_more: mgdTstart(rf) at 1w0d Jun 30 13:06:14.416: //4110//MSM :/ms_play_part: sent: 320, numInBuf: 980 lastFill: 1300, numBytes: 460 Jun 30 13:06:14.416: //4110//MSM :/ms_process: $w$ intEvent MS_E_STOP_PLAY Jun 30 13:06:14.416: //4110//MSM :/ms_stop_play: mgdTstop at 1w0d (cause MS_STOP_COMPLETE) Jun 30 13:06:14.416: //4110//MSM :/ms_stop_play: mgdTstop(rf) at 1w0d Jun 30 13:06:14.416: //4110//MSM :/ms_restart_prompt: Restarting the prompt for > 1 repetions..as it got cutoff Jun 30 13:06:14.416: //4110//MSM :/ms_cutoff: 1w0d Tstop Jun 30 13:06:14.416: //4110//MSM :/ms_cutoff: play cutoff at 1w0d Jun 30 13:06:14.416: //-1//MCM :MR13:/mc_make_packets_DQ: mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 500 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 40 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 460 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 80 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 420 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 120 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 380 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 160 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 340 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 200 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 300 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 240 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 260 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 280 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 220 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 320 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 180 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 360 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 140 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 400 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 100 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 440 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 60 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: (enough data), current_buf: 0x31A6E5A4 thisMcBytesPlayed: 480 Jun 30 13:06:14.416: //-1//MCM :MC6:/mc_make_nohdr_packet: mc->name tone://US_g729_tone_congestion, bytesLeftInBuf: 20 Jun 30 13:06:14.416: //-1//MCM :MR13:/mc_make_packets_DQ: mc_fill_pakList(): status_fillpak 0, / mcr->thisMcBytesPlay 480, mc:2A0FC948 name:tone://US_g729_tone_congestion Jun 30 13:06:14.416: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:14.416: //-1//MCM :MR13:/mc_make_packets_DQ: No more prompts to play: Jun 30 13:06:14.416: //-1//MCM :MR13:/mc_make_packets_DQ: count: 12 Jun 30 13:06:14.416: //4110//MSM :/ms_cutoff: First Buf Play at 1w0d of tone://US_g729_tone_congestion Jun 30 13:06:14.416: //4110//MSM :/ms_cutoff: ms_cutoff() 1w0d, Tstart(iSndDly 0) Jun 30 13:06:14.416: //4110//MSM :/ms_process: >>ms_delete_event(MS_E_int) Jun 30 13:06:15.236: //4110//MSM :/ms_handle_stream_timer: >>ms_start_play() Jun 30 13:06:15.236: //4110//MSM :/ms_start_play: 1w0d mgdTstart(rf) Jun 30 13:06:15.236: //4110//MSM :/ms_start_play: 1w0d mgdTstop(ply) Jun 30 13:06:15.236: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:15.236: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.236: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.236: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.236: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x3000AD60, Type: Event, RefCount: 0 Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.236: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL Jun 30 13:06:15.236: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8F9B0, Type: DataList, RefCount: 0 Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.236: //-1//AFW_:/AFW_Event_New: Event ID: ev_leg_timer Jun 30 13:06:15.236: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.236: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.236: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_Process_GetTimerEvent: Received Jun 30 13:06:15.236: //-1//AFW_:/AFW_Process_GetTimerEvent: Event[APP_EV_LEG_TIMER(1)] { Jun 30 13:06:15.236: //-1//AFW_:/AFW_Process_GetTimerEvent: EXECENV[0x31D29988] Jun 30 13:06:15.236: //-1//AFW_:/AFW_Process_GetTimerEvent: LEG[4110][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:15.236: //-1//AFW_:/AFW_Process_GetTimerEvent: } Jun 30 13:06:15.236: //-1//SSIN:/AFW_SS_MapEvent: No mapping required Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_M_Leg_EventPreProcess: LEG[4110 ][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[4110][LEG_INCCONNECTED(5)][Cause(0)] Jun 30 13:06:15.236: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:15.236: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule Jun 30 13:06:15.236: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_313DD624_0_687505696 Jun 30 13:06:15.236: //4110//AFW_:/AFW_M_TclModule_Action: Jun 30 13:06:15.236: //4110//AFW_:/AFW_TclModule_DefaultEvHandling: Jun 30 13:06:15.236: //4110//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALLDISCONNECT[4],ev_leg_timer[1])---[act_Cleanup]------ Jun 30 13:06:15.236: //4110//TCL :/tcl_CallObjCmd: call close Jun 30 13:06:15.236: //4110//TCL :/tcl_CallCloseObjCmd: close Jun 30 13:06:15.236: //-1//AFW_:/AFW_ExecEnv_CallClose: Exec Env state: 1 Jun 30 13:06:15.236: //-1//AFW_:/AFW_ExecEnv_CallClose: Terminating ExecEnv's root module Jun 30 13:06:15.240: //4110//AFW_:/AFW_Module_Terminate: Terminating Module: TclModule_313DD624_0_687505696 Jun 30 13:06:15.240: //4110//AFW_:/AFW_M_TclModule_Terminate: Module is in the state: ACTIVE Jun 30 13:06:15.240: //4110//AFW_:/AFW_TclModule_Cleaner: lastFailureCause 3 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_4110 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_4110, Cause 16 Jun 30 13:06:15.240: //-1//MSW :/msw_stop: genericStream=0x296DDDD8, reason=MSW_REASON_DISCONNECTED Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: msw_synth_stop: Enter... Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: genericStream=0x296DDDD8, mediaStream=0x300682A8, rtspStream=0x29B9366C reason=MSW_SYNTH_REASON_DISCONNECTED, current_state=MSW_S_PLAYING Jun 30 13:06:15.240: //4110//MSW :/msw_synth_stop: msw_synth_stop: call ms_stop_play()... Jun 30 13:06:15.240: //4110//MSM :/ms_stop_play: mgdTstop at 1w0d (cause MS_STOP_DISCONNECTED) Jun 30 13:06:15.240: //4110//MSM :/ms_stop_play: mgdTstop(rf) at 1w0d Jun 30 13:06:15.240: //4110//MSM :/ms_stop_play: Play Stopped at 1w0d Jun 30 13:06:15.240: //4110//MSM :/ms_stop_play: calling CBF for stream_id 1 Jun 30 13:06:15.240: //4110//MSW :/msu_synth_ms_play_complete: context=0x296DDDDC, use_dynamic=0, dynamicElement=0x0, cause=MS_STOP_DISCONNECTED, stream_id=1, duration=500, rate=0 proto_code=0 Jun 30 13:06:15.240: //4110//MSW :/msu_synth_ms_play_complete: Ignoring: cur. stream=2, resp. stream=1 Jun 30 13:06:15.240: //-1//DPM P14:/dp_delete_mcDynamicS: >dequeue(mcDynamicQ) Jun 30 13:06:15.240: //-1//MCM :MC6:/mc_delete: mc=0x2A0FC948 Jun 30 13:06:15.240: //-1//MCM :MC6:/mc_delete: refCount=1 Jun 30 13:06:15.240: //-1//MCM :MC6:/mc_check_background_load: mc(0x2A0FC948), mc->eof=1 Jun 30 13:06:15.240: //-1//MCM :MC6:/mc_waitq_add: prompt_wait=1F4 prompt_active=0 Jun 30 13:06:15.240: //-1//DPM P14:/dp_delete_mcDynamicS: >free(p_mcDynamicS) Jun 30 13:06:15.240: //-1//MCM :MR13:/mc_delete_read: dequeue(pakList) Jun 30 13:06:15.240: //-1//MSW :/msw_recrd_stop: genericStream=0x296DDDD8, mediaStream=0x31CEA83C, rtspStream=0x29B93674 reason=MSW_RECRD_REASON_DISCONNECTED current_state=MSW_S_IDLE Jun 30 13:06:15.240: //-1//MSW :/msw_recrd_stop: Stream not currently active Jun 30 13:06:15.240: //-1//MSW :/msw_recog_stop: Jun 30 13:06:15.240: msw_recog_stop: genericStream=0x296DDDD8, mrcpStream=0x29B936F8 reason=MSW_RECOG_REASON_DISCONNECTED, current_state=MSW_S_IDLE Jun 30 13:06:15.240: //-1//AFW_:/afw_get_mapped_disc_cause: Mapping requested for Q850 cause (16) Jun 30 13:06:15.240: //-1//AFW_:/afw_get_mapped_disc_cause: Mapping not found for Q850 cause(16) Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 842 type 2 Jun 30 13:06:15.240: //-1//VAAA:0/voip_start_ccapi_rotary_accounting: WARNING: gw-accounting aaa not enabled. return. Jun 30 13:06:15.240: //4110//AFW_:/AFW_FSM_Drive: ACTION END: -------------(samestate[5])--------------- Jun 30 13:06:15.240: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> NULL Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x3000B790, Type: Event, RefCount: 0 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FC08, Type: DataList, RefCount: 0 Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.240: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1 Jun 30 13:06:15.240: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.240: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30008ED0, Type: Event, RefCount: 0 Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FBE0, Type: DataList, RefCount: 0 Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.240: //4110/CD63A95A81EC/VAAA:0/voip_stop_ccapi_accounting: (4110): UID=0 Jun 30 13:06:15.240: //4110/CD63A95A81EC/VAAA:0/voip_stop_ccapi_accounting: error: Bad acct_db Jun 30 13:06:15.240: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.240: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Process_GetCcqEvent: Received Jun 30 13:06:15.240: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_DISCONNECT_DONE(19)] { Jun 30 13:06:15.240: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x31D29988] Jun 30 13:06:15.240: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[4110][LEG_INCDISCONNECTING(6)][Cause(16)] Jun 30 13:06:15.240: //-1//AFW_:/AFW_Process_GetCcqEvent: } Jun 30 13:06:15.240: //-1//SSIN:/AFW_SS_MapEvent: No mapping required Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Object_ShowListeners: MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[4110][LEG_DISCONNECTED(12)][Cause(16)] Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Object_ShowListeners: ) Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Object_RemoveListener: Jun 30 13:06:15.240: //-1//AFW_:/AFW_DataArray_ElementDelete: param name LEG_4110 Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 1 Jun 30 13:06:15.240: //4110//AFW_:/AFW_Module_UnListen: NumObjects: 0 Jun 30 13:06:15.240: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_313DD624_0_687505696 Jun 30 13:06:15.240: //4110//AFW_:/AFW_M_TclModule_Action: Jun 30 13:06:15.240: //4110//AFW_:/AFW_M_TclModule_Action: Module is Terminating Jun 30 13:06:15.240: //-1//AFW_:/AFW_Event_New: Event ID: ev_module_done Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.240: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.240: //4110//AFW_:/AFW_TclModule_ReturnIfDone: Sending Out APP_EV_TCLMODULE_DONE event Jun 30 13:06:15.240: //4110//AFW_:/AFW_Module_ReturnArgEv: Jun 30 13:06:15.240: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.240: //4110//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_313DD624_0_687505696 ---> NULL Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x3000C1C0, Type: Event, RefCount: 0 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Event_Free: CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_4110 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_Object_RemoveAllListener: Jun 30 13:06:15.240: //4110//AFW_:/AFW_ExecEnv_DecrNPendingCmd: PendingCmdCount: 0 Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 1, CmdPending 0 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 1 Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31C39E90, Type: Leg, RefCount: 0 Jun 30 13:06:15.240: //4110/CD63A95A81EC/AFW_:/AFW_M_Leg_Free: Jun 30 13:06:15.240: //4110//MSW :/msw_destroy: Jun 30 13:06:15.240: //-1//MSW :/msw_stop: genericStream=0x296DDDD8, reason=MSW_REASON_DISCONNECTED Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: msw_synth_stop: Enter... Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: genericStream=0x296DDDD8, mediaStream=0x300682A8, rtspStream=0x29B9366C reason=MSW_SYNTH_REASON_DISCONNECTED, current_state=MSW_S_IDLE Jun 30 13:06:15.240: //4110//MSW :/msw_synth_stop: Stream not currently active Jun 30 13:06:15.240: //-1//MSW :/msw_recrd_stop: genericStream=0x296DDDD8, mediaStream=0x31CEA83C, rtspStream=0x29B93674 reason=MSW_RECRD_REASON_DISCONNECTED current_state=MSW_S_IDLE Jun 30 13:06:15.240: //-1//MSW :/msw_recrd_stop: Stream not currently active Jun 30 13:06:15.240: //-1//MSW :/msw_recog_stop: Jun 30 13:06:15.240: msw_recog_stop: genericStream=0x296DDDD8, mrcpStream=0x29B936F8 reason=MSW_RECOG_REASON_DISCONNECTED, current_state=MSW_S_IDLE Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: msw_synth_stop: Enter... Jun 30 13:06:15.240: //-1//MSW :/msw_synth_stop: genericStream=0x296DDDD8, mediaStream=0x300682A8, rtspStream=0x29B9366C reason=MSW_SYNTH_REASON_DISCONNECTED, current_state=MSW_S_IDLE Jun 30 13:06:15.240: //4110//MSW :/msw_synth_stop: Stream not currently active Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8F9D8, Type: DataList, RefCount: 0 Jun 30 13:06:15.240: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.240: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x313DD624, Type: TclModule, RefCount: 2 Jun 30 13:06:15.240: //-1//MSW :/msw_recrd_stop: genericStream=0x296DDDD8, mediaStream=0x31CEA83C, rtspStream=0x29B93674 reason=MSW_RECRD_REASON_DISCONNECTED current_state=MSW_S_IDLE Jun 30 13:06:15.244: //-1//MSW :/msw_recrd_stop: Stream not currently active Jun 30 13:06:15.244: //-1//MSW :/msw_recog_stop: Jun 30 13:06:15.244: msw_recog_stop: genericStream=0x296DDDD8, mrcpStream=0x29B936F8 reason=MSW_RECOG_REASON_DISCONNECTED, current_state=MSW_S_IDLE Jun 30 13:06:15.244: //4110/CD63A95A81EC/AFW_:/decrementDialPeerCallStats: Decrementing call-stat for disconnecting leg, dial-peer [10] Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FA00, Type: DataList, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.244: //4110//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_ExecEnv_CallClose: Exec Env state: 3 Jun 30 13:06:15.244: //4110//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED Jun 30 13:06:15.244: //4110//AFW_:/AFW_Process_GetPriorityQEvent: Received Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_GetPriorityQEvent: Event[APP_EV_TCLMODULE_DONE(220)] { Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_GetPriorityQEvent: EXECENV[0x31D29988] Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_GetPriorityQEvent: MOD[TclModule_313DD624_0_687505696] ( Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_GetPriorityQEvent: ) Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_GetPriorityQEvent: } Jun 30 13:06:15.244: //4110//AFW_:/AFW_M_TclModule_EventPreProcess: Jun 30 13:06:15.244: //4110//AFW_:/AFW_Object_WalkListeners: Jun 30 13:06:15.244: //4110//AFW_:/AFW_M_Object_ShowListeners: START Jun 30 13:06:15.244: //4110//AFW_:/AFW_M_Object_ShowListeners: END Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30000030, Type: Event, RefCount: 0 Jun 30 13:06:15.244: //4110//AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.244: //4110//AFW_:/AFW_M_Event_Free: MODULEDONEEVENT for a Module: TclModule_313DD624_0_687505696 Jun 30 13:06:15.244: //4110//AFW_:/AFW_Object_RemoveAllListener: Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 0, CmdPending 0 Jun 30 13:06:15.244: //-1//AFW_:HN28FA8120:/AFW_M_Event_Free: ExecEnv objCount: 0 Jun 30 13:06:15.244: //-1//SERV:/AFW_Service_ReleaseExecEnv: Script Name = auth cache = true calls = 0 Jun 30 13:06:15.244: //4110//AFW_:/AFW_ExecEnv_UnSetRoot: Execenv = 0x31D29988 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Process_UnLock: pProcess(0x3144788C)=0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x3144788C, Type: Process, RefCount: 1 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30116784, Type: DataArray, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x2A658E3C, Type: DataString, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30054A78, Type: DataString, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D41970, Type: DataArray, RefCount: 0 Jun 30 13:06:15.244: //-1//SCRI:/cam_sa_stopped: Instance: [] ExecEnv: 0x31D29988 Jun 30 13:06:15.244: //-1//AFW_:/AFW_DataList_Requeue: Trying to add element to a list Jun 30 13:06:15.244: //-1//AFW_:/AFW_DataList_GetWrapper: Looking for list element 0x31D29988 Jun 30 13:06:15.244: //-1//AFW_:/AFW_DataList_Requeue: Adding element: Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_IncrRefCount: Object: 0x31D29988, Type: ExecEnv, RefCount: 2 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x313DD624, Type: TclModule, RefCount: 1 Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FB40, Type: DataList, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FA78, Type: DataList, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:15.244: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event Jun 30 13:06:15.244: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: Event(Size=2608) Jun 30 13:06:15.244: //-1//AFW_:/AFW_DataList_New: Jun 30 13:06:15.244: //-1//AFW_:/AFW_Class_Allocate: Malloc Data Space: DataList(Size=40) Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x30000A60, Type: Event, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_Event_Free: Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_IsType: 0: NULL object Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL Jun 30 13:06:15.244: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x31D8FBB8, Type: DataList, RefCount: 0 Jun 30 13:06:15.244: //-1//AFW_:/AFW_M_DataList_Free: Jun 30 13:06:19.096: //-1//SCRI:/ScriptList_CacheCurrent: auth
If I remove the service from the dial-peer in my configuration, the call completes normally using outbound peer 100. I can tell from this debug log that the TCL script alos selects the same outbound peer, but the call fails.
Subject: RE: authentication problem Replied by: Anusha Kannappan on 01-07-2011 05:41:38 AM Hi Wesley,
With regard to the error you are getting, as the authentication is failed the user is denied access and gateway is blocking the call due to which you are not able to complete the call when the service is configured in the dial-peer. Here is the detailed information of the error you received.
I don't think there is any way to set any variable to make the authentication as succeeded in this scenario. But anyway I will cross check with our internal teams over here and keep posted once I receive any updates on the same.
Thanks, Anusha
Subject: RE: authentication problem Replied by: WESLEY PHILLIPS on 04-08-2011 02:43:36 PM I have been able to "sort of" find a solution to this. Since the gateway is incapable of connecting a call when the authentication fails, I will have to stand up a second radius server, configure it on the router, and then rely on redundant servers, so that there is never an instance where the server is "unavailable(au_001)".
