Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Alawi Alkaff on 18-04-2011 06:07:08 PM could anyboldy learn me how can I start with AXLAPI WITH ASP.NET C# what the first steps for that ? the begining is very important .. I tried to understand but i faced some difficult what the wsdl.exe and where can i find it ? what I have to do after install wsdl.exe ? how can use it in asp.net and how can I connect with call manager server ? I hope to help me I need it for asp.net only thank you
Subject: RE: AXLAPI FOR ASP.NET ( Help ) Replied by: Mayank Sharma on 25-04-2011 08:14:06 AM
wsdl.exe comes with your Visual Studio installation. You don't have to install it. You can find it in C:\Program Files\Microsoft Visual Studio 8\SDK\v2.0\Bin or similar. Once you find it, you have to use cmd.exe to use the wsdl file to create a proxy class. It will by default be named as AXLAPIService.cs. Once you have the .cs file, you can add it to your ASP.NET project and then use it as regular class. You do have to make some changes to AXLAPIService.cs file, like the constructor but all this is documented. Good luck.
Subject: RE: AXLAPI FOR ASP.NET ( Help ) Replied by: Alawi Alkaff on 25-04-2011 03:59:53 AM no body!!!
Subject: RE: AXLAPI FOR ASP.NET ( Help ) Replied by: Breno Lucena on 17-01-2012 01:07:15 PM Hello Alawi, I´ve faced the same difficulty. First you have to run WSDL.exe by using the following command: wsdl.exe AXLAPI.wsdl axlsoap.xsd After that you´ll create a AXLAPIService.cs, than, add it to your project and start using the available entities. I really hope it helps you. Regards. Breno.
