Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Angelina Talley on 08-09-2008 04:58:48 PM Hey folks. I have a call flow that wants to use the Record element. Whenever I hit the portion of the call flow with the Record, I get a bad fetch error. It's not related to media files as it plays the greeting for the record element and the beep (both in the initial audio group) and then gets a bad fetch error when the user should begin speaking to record. I can't find anything useful in any log about what could be causing the bad fetch.
As a reference, this is CVP 4.0(2) with IOS version 12.4(15)T7 on the gateway.
Any suggestions on what could cause bad fetch in this case?
Subject: Re: badfetch with Record element Replied by: Matthias Neubacher on 16-09-2008 02:19:48 PM Hi Angelina,
I'm facing the same problem (CVP 7.0(2), IOS 12.4(15)T6)... did you already find a solution?
Thanks, Matthias
Edited by: Matthias Neubacher on 16.09.2008 10:19
Subject: Re: badfetch with Record element Replied by: MICHAEL CLENDENING on 18-09-2008 03:44:09 AM If you use both XML and DTMF grammars in the same application, the VoiceXML interpreter will throw a badfetch error.
Peace, Michael Clendening CCIE 6487 (ISP-Dial)
Subject: Re: badfetch with Record element Replied by: Janine Graves on 18-09-2008 02:08:00 PM Hi Michael , In applications without a Record element, I've often used voice and dtmf "xml" grammars within the same application (although I haven't tried 7.0(2) yet, only 7.0(1)) .
So are you saying that if there's a Record element, then one shouldn't mix these grammars?
Janine
Subject: Re: badfetch with Record element Replied by: Matthias Neubacher on 18-09-2008 06:06:08 PM Hi,
I've found this in my gateway's vxml logs:
*Sep 16 22:34:59.701: //2798//AFW_:/vapp_media_record: codec mismatch between vxml and voip dialpeer. *Sep 16 22:34:59.701: //2798/840A12788F61/VXML:/vxml_vapp_media_record: CALL_ERROR; http://192.168.68.130:7000/CVP/Server at line 16: fail with vapp error VAPP_FAIL
But even setting the codec for all dial peers to the same one (e.g. g711ulaw) doesn't help.
Subject: Re: badfetch with Record element Replied by: Angelina Talley on 19-09-2008 01:18:15 AM When we were on the phone with Cisco support, we were told the proper fix was to set g711ulaw as the only codec on all dial peers. In our case, it hasn't helped. But, it might help in your case.
Subject: RE: Re: badfetch with Record element Replied by: Stacy Johnson on 06-08-2009 09:52:31 PM Can you try adding the codec to the dialpeer directly, instead of using a voice class? I ran into this issue and couldn't get it to work with a voice class, but when I added 'codec g711ulaw' directly to the dialpeer it worked. Hope this helps.
