Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Greg Dowdy on 13-05-2010 01:25:55 PM Hello All, I am writing an application to toggle hospital room status (clean, dirty, occupied, etc and wish to integrate the cisco phones with the app. Having trouble figuring out how to post a variable to a querystring and send it to the server.(Flying blind with limited directions) The simplified menu: menu.xml <?xml version="1.0" encoding="ISO-8859-1" ?> <CiscoIPPhoneInput> <Title>Change Room Status</Title> <Prompt>Enter Room Bed and Status</Prompt> <URL>http://server/ciscoapps/room/products.asp?Products=status</URL> <InputItem> <DisplayName>Room Number</DisplayName>\r\n <QueryStringParam>room</QueryStringParam> <DefaultValue></DefaultValue> <InputFlags>N</InputFlags> </InputItem> <InputItem> <DisplayName>Bed Number</DisplayName>\r\n <QueryStringParam>bed</QueryStringParam> <DefaultValue></DefaultValue> <InputFlags>N</InputFlags> </InputItem> <InputItem> <DisplayName>Status Code</DisplayName>\r\n <QueryStringParam>code</QueryStringParam> <DefaultValue></DefaultValue> <InputFlags>A</InputFlags> </InputItem> </CiscoIPPhoneInput> This menu Posts to products.asp: <% DIM strProducts strbed = Request.QueryString("BED") strroom = Request.QueryString("room") strcode = Request.QueryString("code") stri = "I" mMessage1 = stri&strroom&strbed&strcode mMessage = "Submitted " & strroom & " bed " & strBed & " to status " & strcode Response.Write mMessage %> Code Submitted <% Response.Write mMessage1 ( Delay then mystery code to post mMessage 1 to a server) %> After writing the status change to the phone, I want to delay a bit and then send the variable mMessage1 to a query string, to actually toggle room status, Having trouble getting there and help is appreciated. Cant seem to get it to work correctly. Response.Write("<URL>http://kyinap000044/StatusTracker/ipPhone.cfm?status=string</URL>\r\n") will work if status is set to the actual code that toggles the room status, but am having trouble getting MMessage1 into string and sending after a delay. Response.Write("<URL>http://kyinap000044/StatusTracker/ipPhone.cfm?status=I4151D</URL>\r\n") which tells the cold fusion back end to Input room 415 bed 1 to status D (Dirty) will work everytime. Just cant delay and get MMessage1 into the querystring status. Have tried response.addheader, but either not getting the syntax right or something. Thanks in advance.
Subject: RE: Basic help Replied by: David Staudt on 13-05-2010 02:57:42 PM Not completely clear on the flow, but you can add this HTTP header to the response to trigger a 5 second timed refresh to your designated URL+param: <pre class="de1">Refresh: 5; url=http://www.example.com?param=value </pre>
Subject: RE: Basic help Replied by: Greg Dowdy on 04-06-2010 12:42:20 PM I could never get the <pre class="de1">Refresh: 5; url=http://www.example.com?param=value </pre>to work correcly on the 7940's we have. It seems however that Response.AddHeader "Refresh", "5;URL=http://kyinap000044/StatusTracker/ipPhone.cfm?status=" & Server.URLEncode(mMessage1) will work.
