cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jon Nelson on 31-07-2011 08:04:12 PM
Does anyone have an example of the BOSH binding URL for WebEx Connect integration? I've reviewed the documentation for both WebEx Social and WebEx Connect, but I can't seem to find a good example.
BOSH Binding URL (Ex: https://chat-server:7335/httpbinding) * is what is listed as an example.
TIA
-Jon
Subject: RE: BOSH Binding URL for WebEx Connect
Replied by: Ken Snyder on 04-08-2011 12:27:36 PM
<BUMP> We need an answer here...
Replied by: Jon Grady on 04-08-2011 12:45:49 PM
Hi Ken,
We are working with the BU to get you a definitive answer on this one. We will be back with an update as soon as possible.
Jon
Replied by: Dirk-Jan Uittenbogaard on 14-09-2011 05:08:07 AM
Here's an example I found (with some modifications, not revealing the real URL)
https://im8.ciscowebex.com/aic2
Does that help you? Not sure if this can be completely different for other WebEx customers.
Replied by: Daniel Bender on 31-01-2012 12:31:25 AM
Any update on this one?  Running into the same issue myself.
Replied by: Daniele Salladini on 14-02-2012 04:53:32 AM
Any news?? I've same issue.
I tried with link similar to https://im8.ciscowebex.com obtained by logging with my webex account in https://im.ciscowebex.com, but it doesn't work.
Daniele
Replied by: Daniel Bender on 14-02-2012 11:52:55 PM
I've had a TAC case open for a couple weeks on this.  They went to the BU and received back the following URL to try:
https://im1.ciscowebex.com/isj1
it worked perfectly for me, I hope it works for you as well.
As an aside I can say that integration with CUPS is ridiculously easy, I got it to work on the first try without bothering to read the documentation.  My company will almost assuredly be migrating from Webex Connect to CUPS with XMPP Federations enabled so that people can still chat with Cisco employees (my understanding is that they are wide open for XMPP).  Virtually identical functionality (better in my opinion) and no monthly bill.  It's a no brainer if you ask me.
