Ahmadalkayyali
Contents
  • Introduction
  • Prerequisites
  • Background Information
  • The Five Building Blocks
  • Example: Running a SIP Trunk Change from Start to Finish
  • Verify
  • Troubleshoot
  • Related Information
Introduction
This document describes how I built a repeatable way of working as an enterprise voice and network engineer.
It covers the five things I use on every project: templates, checklists, risk models, validation processes, and rollback procedures.
The goal is simple. Anyone should be able to pick up my work and do it again without me in the room. A good result once is luck. A good result every time is a method.
Prerequisites
Requirements
There are no special requirements for this document. It helps if you have done at least one change on a live voice system, and if you have felt that quiet worry during a maintenance window when calls did not come back the way you expected. That feeling is the reason this article exists.
Components Used
The examples in this document can apply to CUCM, UCCE, CVP, CUBE, Finesse, CUIC, SIP trunks, and other enterprise voice platforms, as well as Cisco IOS, IOS-XE, and Nexus.
Supporting tools I use:
  • A ticket or change system
  • A place to store backups and pre-check output
  • RTMT and whatever monitoring the business already trusts
  • A simple spreadsheet
The information in this document was created from lab and test environments. If your system is live, plan your change window first.
When I started, every change was a fresh start. I opened a blank page, copied steps from an old email, changed a few names, and hoped. Sometimes it worked. Sometimes I spent the night explaining to a business team why their agents could not log in.
The turning point was not a new tool. It was one honest question: if I did this same task next month, would I do it the same way? The answer was no. And that was the problem.
Voice makes this worse than most areas, because one small change can touch many systems. A single SIP trunk change can pull in CUCM, CUBE, the carrier, firewall rules, certificates, call recording, UCCE scripting, and reporting. If you treat that as a one-off, you will forget something. Not because you are careless, but because there is too much to hold in your head at 11 p.m.
So I stopped treating each task as a one-off, and started building a method.
1. Templates
A template is a plan with the moving parts pulled out.
I noticed that most of my change documents were about 80 percent the same. Only the system, the business group, and the test steps changed. So I saved the common part once and left blanks for the rest.
I keep templates for:
  • Change requests
  • Maintenance window plans
  • Pre-check and post-check notes
  • Cutover plans
  • Rollback steps
  • Test call results
  • Communication emails
  • Vendor and carrier coordination
  • Implementation summaries
A template does not need to be complicated. Mine answer simple questions:
  • What are we changing?
  • Why?
  • What systems are impacted?
  • Who needs to be involved?
  • What is the risk score?
  • What is the test plan?
  • What is the rollback plan?
  • How will we know it worked?
The same idea works for config. On CUCM I do not build a new device pool, partition, or route pattern from memory. I keep a naming standard and follow it, so device number 40 looks exactly like device number 1. When everything looks the same, "different" becomes a clue instead of normal life.
Templates also help new engineers. They can follow the structure instead of guessing what belongs in a change plan.
2. Checklists
A template tells me what to write. A checklist tells me what to do around it.
Pilots use checklists. Surgeons use checklists. Not because they forget how to fly or how to cut, but because tired people skip steps. I am a tired person quite often.
Before the change
  • Business approval and maintenance window confirmed
  • DRS backup taken and verified, not just scheduled
  • Database replication healthy on all nodes
  • Certificates checked for expiry
  • DNS and NTP correct
  • Services running, device and agent registration counts recorded
  • SIP trunk and route list status recorded
  • Pre-checks captured and saved to a file
  • Rollback written down and tested
  • Peer review done
  • Carrier or vendor on call if needed
During the change
  • Record the start time
  • Follow the approved steps, in order
  • Capture output or screenshots at each major step
  • Do not change the plan mid-window unless there is a clear reason
  • Stop and reassess if something unexpected appears
After the change
  • Post-checks captured and compared with pre-checks
  • Test calls placed, inbound and outbound
  • Agents able to log in to Finesse
  • Reports and CDR data still flowing
  • Recording working if in scope
  • Monitoring clean for a set period
  • Ticket updated and lessons learned written down
One habit worth calling out: I re-run replication and registration checks about 30 minutes before the window, not just the day before. Things move. A node that looked fine at 9 a.m. is not proof it is fine at 11 p.m.
A checklist does not replace engineering knowledge. It supports it.
3. Risk Models
Not every change is the same size. Adding a description to a device is not the same as renewing certificates on a cluster. Early on I treated them the same, which meant I was either too slow on small work or too fast on big work.
So I score every change before it starts.
Question 1 point 2 points 3 points
User impact — who breaks if this goes wrong?One user or one deviceOne site, one queue, or one business groupWhole cluster, all agents, or all inbound calls
Business impactInternal onlyCustomer calls affectedSales, support, or emergency calling affected
Technical reachOne setting, one systemTwo or three systemsRouting, certificates, database, or SIP path
Recovery — how fast can I undo it?MinutesNeeds a restore or a version switchHard, needs a rebuild or a carrier change
TestingFull test plan possiblePartial test onlyCannot test until it is live
Add the points and you get a score from 5 to 15.
  • 5 to 7 (Low): I do it myself, note it in the ticket.
  • 8 to 10 (Medium): Peer review, change window, rollback written down.
  • 11 to 13 (High): Lab test first, rollback tested, second engineer on the call.
  • 14 to 15 (Critical): Everything above, plus business sign-off, vendor or carrier on standby, and a longer window than you think you need.
This is not fancy math. It is a way to have the same conversation every time, instead of arguing about feelings. It also gives leadership a simple number they can understand.
4. Validation Processes
Validation means proving the system is healthy, with facts, not with hope.
A change is not done because the command finished or the server rebooted. It is done when calls are working.
The rule I follow: capture the same checks before and after, then compare.
For a voice change, that usually means:
  • Phone and device registration counts
  • Route pattern and translation behavior
  • Test calls, inbound and outbound
  • Agent login and state changes in Finesse
  • CUIC reports showing live data
  • Call recording working
  • CDR and CMR data still flowing
  • RTMT alarms and any unexpected service failures
Save the "before" to a file. Run the same checks after. Compare them. If the only difference is the thing you meant to change, the change is good. If something else moved, stop and look. Do not guess.
Two more things I always test:
  • Test what should work. The 800 number reaches the queue. Agents get calls.
  • Test what should NOT work. The old route is really gone. The blocked pattern is still blocked. Toll fraud paths are still closed. People forget this half, and it is where real problems hide.
5. Rollback Procedures
A rollback is the plan for going back. It is written before the change, not during the outage.
The worst place to write a rollback plan is in the middle of a failed cutover, with a manager standing behind you. So I write it while I am calm.
My rollback rules:
  1. Back up first, and verify the backup. On CUCM that means a DRS backup that actually completed, not one that was scheduled and assumed. A backup you have never restored is a wish, not a plan.
  2. Know your platform's undo path before you start. This is important, because rollback is not the same everywhere:
    • CUCM upgrades: the version switch back to the inactive partition, if the upgrade left it usable.
    • Virtual machines: a snapshot, if your support policy allows it, and taken with the system in a supported state.
    • Config changes: the exported config, the previous route pattern, the previous trunk setting, written down exactly as it was.
    • IOS and IOS-XE routers such as CUBE: configure replace from a saved config, or a scheduled reload as a safety net (see the note below).
    • Nexus: NX-OS uses checkpoint and rollback, which is a different mechanism. Take a checkpoint before the change and roll back to it if needed.
    The point is simple: rollback commands depend on the platform. Do not assume the method you use on a CUBE will work on a Nexus switch or a CUCM node. Check the guide for that platform before the window, not during it.
  3. Set a time limit. If the change is not validated within a set time, roll back. I do not "just try one more thing." That is how a 30-minute problem turns into a five-hour outage and an angry morning.
  4. Test the rollback. If it has never been run, it is not a plan.
Note on reload in: On supported IOS and IOS-XE devices, a scheduled reload is a useful safety net for a remote change. If you lock yourself out, the device reloads into the last saved config and you get access back. You cancel it with reload cancel once the change is validated, and you save only after that. Use it only if you understand how it behaves on your platform and software version, because behavior and known bugs vary by release. Check the command reference for your version first. This also does not apply to CUCM, UCCE, or CVP servers, which have their own recovery paths.
Here is what the method looks like on a real change: updating a SIP trunk or a voice routing path.
1. Define the change. Which trunk or route? Which business group uses it? Which calls can be affected?
2. Review dependencies. Do we need firewall changes? Does the carrier need to do anything on their side? Does the contact center team need to test? Is a certificate involved?
3. Score the risk. If it touches inbound customer calls, it is not a small change. If rollback needs the carrier, the score goes up. If we cannot test until it is live, the score goes up again.
4. Run the pre-checks. Trunk status, route list behavior, recent call failures, alarms, registration counts. Save the output.
5. Implement during the window. Follow the written steps. Capture output as you go. Do not improvise.
6. Validate. Test calls in both directions. Check agent behavior if the contact center is in scope. Check recording. Check reports. Compare against the pre-checks.
7. Roll back if needed. If validation fails and the time limit is reached, go back. Do not wait and hope.
8. Document. What worked, what failed, what should be improved next time. Then update the template, so the next engineer starts one step ahead of where you started.
Verify
Use this section to check that the method is working, not just the change.
Ask after each project:
  • Could someone else repeat this from my notes alone?
  • Did I use a template, or did I copy an old email?
  • Did the pre-check and post-check output get saved anywhere?
  • Did anything surprise me? If yes, that surprise belongs in the checklist now.
A healthy sign: the checklist keeps getting a little longer, and the maintenance windows keep getting a little shorter.
Troubleshoot
Problem: The template does not fit this system. Do not bend the work to fit the template, and do not throw the template away. Add a section, or make a second template for that platform. Templates are meant to grow.
Problem: Nobody uses the checklist. It is probably too long. Cut it down to the steps that have actually burned the team before. A ten-item checklist people use beats a fifty-item checklist people skip.
Problem: The risk score feels wrong. That is fine. The score starts the conversation, it does not end it. If two engineers disagree, that disagreement is useful. Write down the reason and move on.
Problem: Rollback did not work. Then it was never tested, or it was the wrong method for that platform. Both are fixable. Test it next time, and write the platform-specific steps into the plan.
Related Information
The point of all this is not paperwork. It is this: I can hand my work to someone else, walk away, and the calls keep flowing.
One good deployment proves I got lucky. A method that works on the tenth deployment, on a platform I have not touched in a year, even when I am not there, proves something real.
Start with one template and one checklist. Add to them each time something bites you. In a year you will have a system, and you will not remember building it.
Cisco references worth reading:
