cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Jan Aarts on 03-09-2012 09:12:10 AM
with this code
AddRemoteDestinationReq MyDestination = new AddRemoteDestinationReq();
        StandardResponse _Response = new StandardResponse();
        XRemoteDestination _Destination = new XRemoteDestination();
        _Destination.name = this.TxtUserID.Text + "-RDI" ;
        _Destination.destination = this.Lbl_E164.Text;
        _Destination.answerTooSoonTimer = "500";
        _Destination.answerTooLateTimer = "16000";
        _Destination.delayBeforeRingingCell = "0";
        _Destination.Item = this.Txt_RDP.Text;
        _Destination.enableMobileConnect = true;
        _Destination.timeZone = "Etc/GMT";
        _Destination.isMobilePhone = false;
        MyDestination.newRemoteDestination = _Destination;
        _Response= MyAxlServer.addRemoteDestination(MyDestination);
I get:
  InnerException {"Value of ItemElementName mismatches the type of XDevice; you need to set it to ItemChoiceType13.@dualModeDevice."} System.Exception {System.InvalidOperationException}
is there someone that can tell me what I'm doing wrong?
Subject: RE: C# Add remote destination
Replied by: Jan Aarts on 11-09-2012 05:24:53 AM
Nobody who can help me?
is there maybe another way I can try?
Subject: Re: New Message from Jan Aarts in Administration XML (AXL) - Administration
Replied by: Erick Wellnitz on 11-09-2012 09:38:11 AM
I think I had to use SQL to add a remote destination and there was another odd place I had to access for all functionality.  This was for version 8.0 at the time.
It should be in a post here in the dev community.
Sent from my iPad
On Sep 11, 2012, at 4:26 AM, "Cisco Developer Community Forums" <cdicuser@developer.cisco.com> wrote:
> Jan Aarts has created a new message in the forum "Administration XML Questions":
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/axl/forums/-/message_boards/view_message/6473319>
> or simply reply to this email.
Subject: RE: Re: New Message from Jan Aarts in Administration XML (AXL) - Administra
Replied by: Jan Aarts on 19-09-2012 10:10:58 AM
I think I have found the post but no SQL commands are in ther
can you please share the sql Queries?
Sent from my iPad
brian.yule
Community Member
I'm working on the same thing in c#.
This isn't tested, but try this:
var userUpdate = new AddRemoteDestinationReq
                remoteDestination = new XRemoteDestination
                    destination = phoneNumber,
                    enableMobileConnect = "true",
                    ItemElementName = ItemChoiceType16.remoteDestinationProfileName,
                    Item = new XFkType(){
                        Value=  remoteDestinationProfileName
                    name = phoneNumber
