cdnadmin
Community Member
This document was generated from CDN thread
Created by: Erick Wellnitz on 25-10-2013 12:30:06 PM
So, the following has been obsolete since .NET 2.0 yet Cisco's documentation keeps using this code.
1public AXLAPIService(string ccmIp, string user, string password)
2{
3  System.Net.ServicePointManager.CertificatePolicy = new BruteForcePolicy();
4  this.Url = "https://" + ccmIp + ":8443/axl/";
5  this.Credentials = new System.Net.NetworkCredential(user, password);
6}
When using this code from documentation the following warning is given:
Warning 1 'System.Net.ServicePointManager.CertificatePolicy' is obsolete: 'CertificatePolicy is obsoleted for this type, please use ServerCertificateValidationCallback instead. [url=http://go.microsoft.com/fwlink/?linkid=14202']http://go.microsoft.com/fwlink/?linkid=14202' C:\VS Projects\AXLAPIService\AXLAPIService\AXLAPIService.cs 1751 9 AXLAPIService
Would anyone be able to guide me in changing the Cisco documented code to the new ServerCertificateValidationCallback?  I'm not quite understanding how to change this based on microsoft's documentation.
Subject: RE: C#Proxy class and Cisco's obsolete code
Replied by: MARIO POIER on 05-11-2013 09:50:37 AM
This is in VB.NET...
Create a new class:
Imports System.Net
Imports System.Net.Security
Imports System.Security.Cryptography.X509Certificates
Public NotInheritable Class SSLValidator
    Private Sub New()
    End Sub
    Private Shared Function OnValidateCertificate(sender As Object, certificate As X509Certificate, chain As X509Chain, sslPolicyErrors As SslPolicyErrors) As Boolean
     Return True
    End Function
    Public Shared Sub OverrideValidation()
        ServicePointManager.ServerCertificateValidationCallback = AddressOf OnValidateCertificate
        ServicePointManager.Expect100Continue = True
    End Sub
End Class
Then modify the code you'd used ealier to the following:
Public Sub New(ccmIp As String, user As String, password As String)
        SSLValidator.OverrideValidation()
        Me.Url = "https://" & ccmIp & ":8443/axl/"
        Me.Credentials = New System.Net.NetworkCredential(user, password)
End Sub
I am curious to know how long it takes for the connection to the CUCM server to occur. For me it is ~40 seconds and I can't figure out why?
