cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: JOHN GUY on 22-03-2013 08:47:55 PM
I reviewed several posts with regards to sending serial commands using the USB port on the C20
Does anyone the serial IR commands sent between the Cisco remote control and the camera/codec?  Since the C20 doesn't have a RS2323 9 pin interface I would to know if the IR commands are documented?  I would like to send commands to a Crestron controller
Thank you
john
Subject: RE: C20 Infra Red Serial Commands with Crestron
Replied by: BRIAN STABINGER on 23-03-2013 05:42:46 AM
I'd assume the IR commands are the same as those for the other codecs in the C-series. I'd also venture to guess these are the same (or at least useable enough) as those for the MXP.
Understanding there is no available DB9/Serial port, why not control the deveice via LAN? It's essentially the same (if not identical) protocol/API.
Brian.
Replied by: JOHN GUY on 23-03-2013 10:03:28 AM
Hi Brian,  First of all thank you for responding.  I'm only aware of sending serial commands from the Crestron Controller to a physical port (RS232-dB9)or IR (Remote Control signals) on the C40.  But since the C20 doesn't have the RS232 interface my only knowledge is sending IR commands.  Can you explain how to send commands to/From Crestron/Cisco C20 over the LAN?  Maybe a CCO doc or something from Crestron?  This will solve my trouble to control the Codec using a Crestron Controller.  Thank you -John
BRIAN STABINGER:
Brian.
Subject: Re: New Message from Danny De Ridder in TelePresence Developer - Crestron C
Replied by: Danny De Ridder on 23-03-2013 02:28:49 PM
The special Y-cable gets connected
to the camera port and fans out in a connector for the camera and a DB9 for a serial async device. There is an ordering code for this Y-cable.
Sent from Samsung Mobile
-------- Original message --------
From: Admin Tandberg Developer <cdicuser@developer.cisco.com>
Date:
To: cdicuser@developer.cisco.com
Subject: New Message from Danny De Ridder in TelePresence Developer - Crestron Control: Re: New Message from JOHN GUY in TelePresence Developer - Crestron Control:
Danny De Ridder has created a new message in the forum "Crestron Control": -------------------------------------------------------------- Hello,
there's a special cable for the C20
Date:
Subject: New Message from JOHN GUY in TelePresence Developer - Crestron Control: RE: C20 Infra Red Serial Commands with Crestron
JOHN GUY has created a new message in the forum "Crestron Control": -------------------------------------------------------------- Hi Brian, First of all thank you for responding. I'm only aware of sending serial commands from the Crestron Controller to a physical port (RS232-dB9)or IR (Remote Control signals) on the C40. But since the C20 doesn't have the RS232 interface my only knowledge is sending IR commands. Can you explain how to send commands to/From Crestron/Cisco C20 over the LAN? Maybe a CCO doc or something from Crestron? This will solve my trouble to control the Codec using a Crestron Controller. Thank you -John
BRIAN STABINGER:
Brian.
To respond to this post, please click the following link: http://developer.cisco.com/web/telepresence-developer/forum/-/message_boards/view_message/13441136 or simply reply to this email.
To respond to this post, please click the following link: http://developer.cisco.com/web/telepresence-developer/forum/-/message_boards/view_message/13446204 or simply reply to this email.
Subject: Re: New Message from JOHN GUY in TelePresence Developer - Crestron Control:
Replied by: Danny De Ridder on 23-03-2013 02:22:30 PM
Date:
BRIAN STABINGER:
Brian.
Replied by: BRIAN STABINGER on 24-03-2013 08:33:19 AM
I did not realize there was this DB9 dongle cable. Good to know! Thanks, Danny.
You can get the IP module here:
http://developer.cisco.com/web/telepresence-developer/integrator-modules/crestron-codec-c60c90
it says'C60 and C90', butI've used this with the C20 as well. Some of the hardware functions obviously won't apply, but otherwise it works great.
You could also use Crestron's serial module(s) by routing the tx/rx through a TCP/IP client. I had to do this a long time ago, and my recollection is that upon TCP/IP connect you'll need to "manually" enter the telnet log-in info. Not a big deal, but you may as well just use the above module.
Replied by: Danny De Ridder on 25-03-2013 08:09:39 AM
The partnumber for the C20 cable is CAB-C20-RS232-DBG=
Replied by: JOHN GUY on 25-03-2013 08:23:45 AM
Danny De Ridder:
Hi Danny, Thank you for the Part Number of the cable.  The Million dollar question is to find the Serial Commands permitted using the USB port and cable to communicate between control products such as Crestron and AMX.  Are they the same as a C40 with a RS232 interface?  Are the serial commands noted in a CCO document?  This information would be greatly appreciated.  Thank you -John
Replied by: Danny De Ridder on 26-03-2013 03:21:41 AM
is the the info you are looking for?
http://www.cisco.com/en/US/docs/telepresence/endpoint/quick-set-sx20/tc6/api_reference_guide/codec_sx20_api_reference_guide_tc60.pdf
Danny.
Replied by: JOHN GUY on 26-03-2013 07:23:50 AM
BRIAN STABINGER:
Brian.
Hi Brian, Are you familiar with the commands to control a C Series Codec over the LAN?  If so, is there documentation on Cisco or Crestron's Web Sites? Thank you -John
Replied by: David Bruun-Lie on 02-04-2013 08:53:09 AM
John,
The IR would be the last thing you should use to control the Cisco/TANDBERG devices. You should either use Serial (as discussed how to get working on C-20 (similiar solution, although different Y-cable for SX20)) OR use IP. There are modules for Crestron for both Serial and IP. the IP version requires to enable telnet on the codec but once enabled the programming will be EXACTLY the same for IP as it is for Serial (only difference will be the connection logic in the crestron program).
Using IR commands over Serial/IP is also discouraged. All functionality is available on the API as commands, configurations, statuses and events.
Cheers,
David
Replied by: JOHN GUY on 02-04-2013 09:27:16 AM
Hi David,
I appreciate the feedback.  Where can I locate the Telnet module for Crestron and a C20/SX20?
Thank you
John
Replied by: David Bruun-Lie on 02-04-2013 09:32:55 AM
Right here on this site: http://developer.cisco.com/web/telepresence-developer/integrator-modules/crestron-codec-c60c90
Its not documented but it supports the C20 and SX20 too.
David
