cdnadmin
Community Member
This document was generated from CDN thread
Created by: GYSS Nicolas on 06-07-2011 06:10:19 PM
I'm working on the C20 codec in the 4.1.2 firmware.
In this version, when I try to reach the XML files by http://xxxx/getxml?location=/Status/Call, there's a prompt displayed which needs login and password. I want to skip this step by a script or something else.
If it's not possible, I'm wondering how I can manage the C20 by SOAP?
Thank you
Subject: RE: C20 Management
Replied by: David Bruun-Lie on 07-07-2011 03:25:58 PM
what you want to bypass is security! I think our customers would be very unhappy if you could skip this. It's standard authentication so you should be able to implement it without too much difficulty.
Cheers,
David
