cdnadmin
Community Member
This document was generated from CDN thread
Created by: joshua zimmerman on 08-03-2010 11:01:39 PM
I have Ordered the Serial Cable for the C20 Part number 117727 (c20 serial y cable )
i am having problems with both the 1.2 serial mod and the 1.3 mod which one should i use
thanks
Joshua Zimmerman
System programmer
Subject: RE: C20 With Serial Cable
Replied by: David Bruun-Lie on 09-03-2010 11:49:50 AM
Hi Joshua,
its a bit difficult for me to help you with your problems without knowing what problems you are experiencing. But anyhow I suggest using v 1.3 as this is the latest and has the most complete feature set and some speed improvements compared to v1.2.
