cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jignesh Parmar on 26-01-2012 04:43:42 AM
HI All,
I have Codec C60 having Two Cameras PrecisionHD1080p camera connected over UTP cables through Extron DVI201.
when I switched On the codec i am not getting camera Iamge from Primary but when i removed HDMI Cable form Codec side which is coming from Pri.Camera theough Extron DV201 Tx & Rx to HDMI Monitor Camera Image is getting displayed.
and then if i connect HDMI Cable to Codec, Camera Image is getting displayed through Codec C60
Also checked when image is not getting displayed throgh Pri Camera, connected camera directly though HDMI Cable to codec , image is getting displayed through codec.
SO now exactly is the issue, not able to trace.
Thanks in advance.
Jignesh
