cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: joshua zimmerman on 04-02-2010 06:06:17 PM
Hey all,
I am using the c 60 mod for the c20 and it works great, except for the directory.  if i use the remote and input information into the phonebook , if i poll the device locally or globally there is no information present. anyone else have this problem??
or am i missing something
thanks
joshua b zimmerman
Subject: RE: C60 Mod for C20 Device >> Directory issues
Replied by: David Bruun-Lie on 05-02-2010 04:37:18 PM
Hi, which version of the module are you using. TC 1.1 required version 1.1 of the module. TC 2.0 and higher require version 1.2 or higher of the Crestron module. Apart from that it should work.
David
