This document was generated from CDN thread
Created by: Todd Curry on 22-03-2010 11:15:13 PM
One of my dealers is integrating a C90 (TC3.0) and has used the audio application to configure a lectern microphone into a new input group and connected that to the normal far-end output as well as a new output to feed some local speakers for local reinforcement.
That output is being fed with a delay of about 25 mS regardless of processing settings on the microphone (tried turning off echo control, AGC, Noise reduction to test any change).
Is this normal, or are there other settings?
Thanks.
Subject: RE: C90 Audio Matrix Delay?
Replied by: Roger Boe on 01-06-2010 11:21:14 AM
Hi Todd,
I believe this is normal. When turning on reinforcement the delay is already reduced. What exactly are you looking for? Do you need less delay?
Best regards
Roger
