cdnadmin
Community Member
This document was generated from CDN thread
Created by: Holbrook Bunting on 04-07-2012 08:55:51 PM
Just curious how easy or hard it would be to write say, two simple scripts,
script one, which would be called when a user dials, say, *60
have an audio prompt say, press 1 to add a number, 2 to remove
a number, 3 to list blocked numbers and so forth.
When they add or remove a number, it would add say
callers_extension:number_to_be_blocked
Now, on to the second script. When we get an incoming call from the pstn/sip trunk
to the above persons number, it looks at the list. If there is a match between the
destination and the callers number, we play a message saying that their call is not
being accepted and hangup, else do nothing and pass the call through.
Subject: RE: Call blocking script(s)
Replied by: Raghavendra Gutty Veeranagappa on 05-07-2012 04:41:12 AM
Hi Holbrook,
please raise developer support case we will help you to create tcl script for your requirements. For more information you can refer below link.
http://developer.cisco.com/web/devservices/alldevs
Raghavendra
