cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 19-03-2004 10:15:50 PM
How can I access the unique call ID, [b:7bafbb4fe1]172.21.5.19.1079110741031.0.AcmeBankandTrust[/b:7bafbb4fe1], in an element that is programmed in java? I think the APIBase.getSessionId() might do what I need. Am I correct?
Call long entry
172.21.5.19.1079110741031.0,172.21.5.19.1079110741031.0.AcmeBankandTrust,0,1,AcmeBankandTrust,03/12/2004 09:59:01
Subject: RE: Call Logging
Replied by: Michael Bochynski on 19-03-2004 10:26:01 PM
Yes, you are right. [b:d680b171ea]getSessionID()[/b:d680b171ea] from APIBase package will return call ID as a String.
Michael
