cdnadmin
Community Member
This document was generated from CDN thread
Created by: nisar valappil on 07-03-2011 09:44:05 AM
one of the client using edge 95. They are using cisco ip phone also. They want audio calls from ip phone to codec and codec to ip phone. So edge 95 support this ? if support how to configure codec and how to add codec on the CME ( cisco call manager express) ? please give me solution as soon as possible. For the codec configuration i didnt found TFTP server settings on the codec ? edge 95 can we configure TFTP server ?
Subject: RE: call manager and codec
Replied by: Johan Randby on 08-03-2011 10:25:02 AM
Hi Nisar
You will be able to do this with a SIP trunk between a VCS and a UCM(7.0 is tested) when running F9.0 on your MXP. Check http://www.tandberg.com/support/video-conferencing-knowledge-base/interop/index.jsp for interoperability.
If you have further questions on how to do this, please use our support channel, as stated below.
This forum is for integrators and developers only and the topics should therefore be around integration and development of solutions with TANDBERG equipment only. This is NOT a product support channel. If you have support related questions please contact your local TANDBERG representative.
BR Johan
