Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: [email protected] (simulated) on 09-07-2012 12:10:14 PM Hi,
I'm a newbie in JTAPI app and I'm trying to reuse a JTAPI app I have not written.
Basically this app is supposed to monitor placed/received calls on cisco phone. The issue is that I can retrieve extensions that has to be monitored but I never receive any call notification.
If someone has a quick idea, it would be helpfull, I'm using a CUCM 8.6.
public class ProvController implements ProviderObserver, CallObserver { private Config param; static Condition conditionInService = new Condition(); Terminal[] p; int termIndex = 0; private boolean done = false; private Terminal myTerminal; Calendar timer; Provider provider; public void Start(Config param) { setParam(param); try { JtapiPeer peer = JtapiPeerFactory.getJtapiPeer(null); System.out.println("Récupération des Peers"); String providerString = param.getCucmHost() + ";login=" + param.getCucmLogin() + ";passwd=" + param.getCucmPassword() + ";"; System.out.println("Contacting:"+providerString); provider = peer.getProvider(providerString); provider.addObserver(this); conditionInService.waitTrue(); Address[] tblAddress = provider.getAddresses(); for (Address a : tblAddress) { if((Integer.valueOf(a.toString())> Integer.valueOf(param.getCucmExtDebut())) && (Integer.valueOf(a.toString()) < Integer.valueOf(param.getCucmExtFin()) )){ System.out.println("Ecoute de l'extension " + a.toString()); provider.getAddress(a.toString()).addCallObserver(this); } } } catch (Exception e) { System.out.println("Exception dans le démarrage du provider controller: " + e.toString()); } } public void callChangedEvent(javax.telephony.events.CallEv[] callEv) { System.out.println("Event received"); //it never happen }
Subject: RE: Call Observer issue Replied by: Mohan Potluri on 09-07-2012 07:11:07 PM You may want to try jtrace sample app that displays the events in a window. Jtrace sample app is available in Program Files\JTAPITools when you install Cisco JTAPI.
