This document was generated from CDN thread
Created by: Robin Zhu on 12-04-2012 02:45:04 PM
I've been asked to do pressure test for UCCX, and my idea is to code script via JTAPI to simulate 300~400 calls to route point in CUCM. Can someone advice the rough steps, and will be nice if any example?
Subject: RE: Call Simulator
Replied by: David Staudt on 12-04-2012 04:44:27 PM
There is some simple sample code in the JTAPI documentation that shows how to make/answer a call. It should be possible to extend this to repeat without too much difficulty.
You may also be able to use a SIP trunk and a SIP bulk call generator (e.g. SIPp) to launch large scale test calls, with the added benefit of testing media and scripted scenarios.
