cdnadmin
Community Member
This document was generated from CDN thread
Created by: Phani Venigalla on 01-08-2013 05:55:37 PM
Hi, I am using call studio9.0, I am trying to debug very simple application in call studio. I am getting following error  "Connecting...
Prompt: I'm sorry, there was a problem with this application. Please call back later. Thank you. (/CVP/audio/error.wav)
Disconnected."  where as this application works on Call Studio 8.5. Please advise.
Subject: RE: Call Studio 9 Applicatio
Replied by: Phani Venigalla on 01-08-2013 06:16:58 PM
Hi Mike, I just created folder structure in call studio matchine as C:\CISCO\CVP\VXMLServer to deploy. But when i debug through call studio the logs should create in C:\Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_9.0.1-SNAPSHOT\AUDIUM_HOME\applications\TestCVP9\logs but its not even creatting any logs, I did check logs under AUDIUM_HOME directory it shown as "SERVER ERROR: There was a problem loading classes from CVP_HOME\VXMLServer/common. The error was: There was a problem loading classes from CVP_HOME\VXMLServer/common. The root cause was: java.lang.NoClassDefFoundError: javax/mail/Authenticator
Replied by: Michael Aossey on 01-08-2013 06:06:22 PM
Hi Phani,
When debuging in call studio there should be activity and error logs just there are in a production VXML server with the application deployed.  Have you reviewed the logs for errors?  This will tell you why it is erroring out.
-Mike
Replied by: Michael Aossey on 01-08-2013 06:48:01 PM
Looks like your application is trying to send email.  You have to add the mail.jar and activation.jar to the debug instance of tomcat for this to work.  See this link: http://stackoverflow.com/questions/1630002/java-lang-noclassdeffounderror-javax-mail-authenticator-whats-wrong
Subject: Re: New Message from Phani Venigalla in Customer Voice Portal (CVP) - Gener
Replied by: Janine Graves on 01-08-2013 10:48:54 PM
Studio 9 debugger is missing the mail.jar file. Find it on VxmlServer
and copy it into the corresponding debugger directory.
Replied by: Phani Venigalla on 01-08-2013 11:30:06 PM
I didnt find any mail.jar file in Vxmlserver, i have downloaded from Oracle.com site. please advise where do i need to copy this jar file.
Replied by: Janine Graves on 02-08-2013 09:32:54 AM
Look it up on Google. It's a standard part of Tomcat. -- Janine Graves
Subject: RE: Re: New Message from Phani Venigalla in Customer Voice Portal (CVP) - G
Replied by: Steve Earl on 02-08-2013 09:42:36 AM
Put the jar file here: %CVP_HOME%\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_9.0.1-SNAPSHOT\CATALINA_HOME\webapps\CVP\WEB-INF\lib
Replied by: Phani Venigalla on 02-08-2013 09:16:22 AM
I have mail.jar file , in which path exactly i need to copy this  jar file under studio debugger.
Replied by: Phani Venigalla on 02-08-2013 09:51:46 AM
I wonder, this is a simple application it worked on call studio 8.5 through studio debugger. Problem while executing through call studio 9.0. I am not sure why its trying to load classes in mail.jar file. I am not trying to send any mail from my application.
Replied by: Phani Venigalla on 02-08-2013 10:06:55 AM
Thanks Steve, It works.
