cdnadmin
Community Member
Subject: RE: New Message from Bill King in Customer Voice Portal (CVP) - CVP - All V
Replied by: GEOFFREY THOMPSON on 27-08-2012 07:38:28 PM
You can use any of the VXML properties listed in the W3 document.
I’ve used the ones around the “fetch” area and also the dtmf termination character.
Geoff
This document was generated from CDN thread
Created by: Bill King on 27-08-2012 06:24:32 PM
Hello, I apologize if this is a dumb question or has been covered previously, but I haven't been able to find an answer for it anywhere (Support Community, here, Docwiki, etc). Is there a list of the different command options that are available within the Call Studio properties area? So for example, fetchtimeout, etc.? Does anyone have suggestions for a good list of these? I found some information on the World Wide Web Consortium site as well, but didn't know if there was anything anyone else might recommend. Thank you for any suggestions.
Bill
Subject: Re: New Message from GEOFFREY THOMPSON in Customer Voice Portal (CVP) - CVP
Replied by: Janine Graves on 27-08-2012 08:12:28 PM
There is an IOS VoiceXML Programming reference manual that has the
different VoiceXML properties that the gateway supports. It also
contains things like the different VoiceXML events, etc.
http://www.cisco.com/en/US/docs/ios/voice/vxml/developer/guide/dalttl.html
Subject: RE: Call Studio properties reference?
Replied by: Hemal Mehta on 28-08-2012 08:05:29 AM
Look at this link for voice  xml 2.0:
http://www.w3.org/TR/voicexml20/
Look for section 6.  These should be supported depending on whether IOS is 2.0/2.1 compliant.
