This document was generated from CDN thread
Created by: Chikeobi Njaka on 07-08-2011 07:29:49 PM
While trying to figure out what type of event can be reliably depended on to identify a certain event, there are many events that occur for which I don't have an event ID. Most of the identifiable events (non-Cisco) are in the 200 range. There are others that are in the 100 range. Non of these events are defined in the Constant Field Values. Where can I find the definition of all the events defined under javax.te4lephony....?
Thanks.
Subject: RE: callChangedEvent ID values
Replied by: Joseph Moskie on 08-08-2011 02:49:04 PM
The Cisco Events are defined in com.cisco.jtapi.CiscoEventID.
