cdnadmin
Community Member
This document was generated from CDN thread
Created by: Randy Ott on 27-03-2012 07:46:57 PM
    We want to use the 1080p4xS2 with the C40, and also use the camera as a room monitor.  We need to disconnect the HDMI input to the C40 during the room monitoring process, but I want to maintain control through the C40.  So with the camera HDMI not connected (switched away), will the RS232 control signals continue to control the camera?
Cheers
Randy
Subject: RE: Camera control without HDMI connection
Replied by: null on 28-03-2012 03:07:51 AM
Randall O Ott:
Cheers
Randy
Hi Randy - the control chain is separate from the video chain.  As long as you have a working camera control cable hooked up to the 12X camera, the codec should be able to see it and control it.  The command to check this is xStatus Camera 1 (assuming the 12X is first in the control chain).
Also, keep in mind that all 12X cameras have both HDMI and HD-SDI outputs, which are hot at all times.  In particular the S2 camera has updated HD-SDI electronics and should work with any 3rd party HD-SDI device.
regards/
/enrico conedera
tsbu solutions manager
Replied by: null on 28-03-2012 06:24:40 PM
Hi Enrico,
 closed-eyes   Exactly what I wanted to hear and expected.  I appreciate the prompt resonse !
Thanks Enreico
ROO
