cdnadmin
Community Member
This document was generated from CDN thread
Created by: Niklas Andersson on 14-10-2009 02:30:47 PM
Hi I’m controlling a C90 codec with the Crestron macro 1.2
When i store and recall presets all cameras (2 in my case) are affected (PTZ) not only the one that is controlled.
According to the api there is a "Type" that should be specified in the string as
"All" or Camera".
The macro sends "Type: Camera" to the codec but when i recall a stored preset it clearly affects all of the cameras.
I don’t know if this is an Codec or API issue.
Any ides?
Best Regards
Niklas
Subject: RE: Camera Preset
Replied by: David Bruun-Lie on 19-10-2009 01:04:48 PM
Hi Niklas,
"Type: Camera" indicates that a preset only stores presets on the camera positions (for ALL cameras). Type: All" is currently for future usage when more than just camera positions can be stored in a preset. As an example, on the MXP series, a preset also stores audio settings.
So the behaviour you are seeing with all cameras being affected by a preset recall is intentional.
I guess an extension of a camera preset store/recall could be that you could specify that only certain cameras should be affected?
David
Replied by: Valentin Ichim on 21-10-2009 02:49:26 PM
Hi David,
Is it available a facility for Crestrom module for C60 / C90 for integration with BOSCH DCN discussion system ? I am reffering to the TANDBERG HD camera / cameras conected to the codec changing the presets acc. to the open / close mics from DCN system. BOSCH has this functionality with their dome camera, but I wanted to know if it fits also for TANDBERG HD cameras( using Crestron module ). DCN system could send to Crestron the open mic information ( in fact the mic ID that is open ).
Thank you !
Replied by: David Bruun-Lie on 21-10-2009 03:14:45 PM
Hi Valentin,
Integration with specific 3rd party solutions is something that we try to keep out of our modules, but our modules should be easy to use together with other modules to make solutions like the one you have described here.
If there exists Crestron modules for Bosch DCN then this should be a piece of cake. Making a program with the two modules together an connecting open mic signal from the DCN to the Camera_Near_End_Preset_[1-15] signals on the TANDBERG module that recalls the camera presets should do the trick!
Good luck!
David
