cdnadmin
Community Member
This document was generated from CDN thread
Created by: Richard Rhinehart on 16-12-2011 12:22:24 PM
I have written a class for call end and was wondering what values in what objects I should look for. This is cvp 8.5 stand alone.  Many Thanks in advance!
I've tried calling in and then hanging up in a menu but the result is "normal".
<font size="2" color="#7f0055"><font size="2" color="#7f0055">
public
</font></font>
</font>
public void onEndCall(CallEndAPI callEndAPI) throws AudiumException{<font size="2">
String Number = callEndAPI.getElementData(
</font>
"Number", "value");<font size="2">
String Id = callEndAPI.getElementData(
</font>
"Id", "value");
String result = callEndAPI.getCallResult();
<font size="2">
System.
</font>
out.print(result);<font size="2">
callEndAPI.addToLog(
</font>
"CALLRESULT", result);
class ActCallEnd implements EndCallInterface{<font size="2">
</font>
Rick
Subject: RE: Capturing Call Abandon
Replied by: Janine Graves on 16-12-2011 06:25:43 PM
You need to check if getHowCallEnded is equal to the string 'hangup'
Janine
public
</font></font>
</font>
</font>
</font>
"Id", "value");
<font size="2">
System.
</font>
</font>
</font>
Rick
Replied by: Richard Rhinehart on 17-12-2011 05:05:55 PM
Thanks Janine worked perfectly. I was looking for code blocks but couldn't find them sorry for the html.
Subject: RE: New Message from Janine Graves in Customer Voice Portal (CVP) - CVP - A
Replied by: GEOFFREY THOMPSON on 16-12-2011 07:14:09 PM
How can we tell, when instead of posting code, you¿ve posted HTML? Some of the email clients that use this program make posts extremely difficult to read. Please post plain text.
Geoff
