This document was generated from CDN thread
Created by: null on 11-09-2006 02:55:45 PM
Is there any way to capture what the caller actually says (i.e. recording their utterances)? I know we can do that on the Nuance server, but I was wondering if there was a way to record it on the Audium client side?
-sandra
Subject: RE: capturing callers' utterances
Replied by: Michael Bochynski on 12-09-2006 03:32:29 PM
Hi Sandra,
You would have to check your voice browser settings for recording of the actual prompts. Most of the browsers should have this setting available, however it is vendor dependant.
Note that Call Services does not communicate with the caller directly, it is a voice browser, or an ASR engine in this case, that interacts with a caller. Call Services will receive the recognized input whether it is a DTMF or Voice.
Hope this helps,
Michael
Replied by: Michael Bochynski on 12-09-2006 06:00:04 PM
Hi Sandra,
One point I would like to clarify here. The actual voice recognition is done by the ASR engine. The voice browser, like Call Services, receives already recognized utterance, hence the actual voice input can be gathered only on the ASR side.
I mentioned voice browser in my first post, since in some scenarios vendors ship voice browser, TTS and ASR engine bundled together as a one package. However, in your particular situation you would have to refer to your ASR vendor â¿¿ Nuance â¿¿ not the voice browser vendor â¿¿ CVP.
Hope it explains everything
Michael
