Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Michael Schmidt on 06-05-2013 07:30:04 AM Hi,
I want to use such Perl-Script to run a sql query against CAR Database like I can do this sql directly from CLI at CUCM: run sql car select * FROM tbl_billing_data where datetimestamporigination between '2013-05-06 00:00:00' and '2013-05-07 00:00:00' ORDER BY datetimestamporigination But when I try to use the "car select" command in the Perl-Script I get back the error "A syntax error has occurred". Is it possible to use "car select" in a Perl Script or is there any other way to schedule such a SQL like "run sql car select * FROM tbl_billing_data where datetimestamporigination between '2013-05-06 00:00:00' and '2013-05-07 00:00:00' ORDER BY datetimestamporigination"? 1 2#!/usr/bin/perl 3 4use warnings; 5use strict; 6use SOAP::Lite; 7use Data:umper; 8 9my $DEBUG = 1; 10my $cucmip = '127.0.0.1'; 11my $axl_port = '8443'; 12my $user = 'AXLUSER'; 13my $password = 'AXLPASS'; 14my $error_text; 15 16BEGIN { 17 sub SOAP::Transport::HTTP::Client::get_basic_credentials { 18 return ($user => $password) 19 }; 20} 21 22use SOAP::Lite +trace => 'debug'; 23 24my $cm = new SOAP::Lite 25 encodingStyle => '', 26 uri => 'http://www.cisco.com/AXL/API/1.0', 27 proxy => "https://$cucmip:$axl_port/axl/" ; 28 29my $axl_sql = "SELECT * FROM device"; 30 31print "\$axl_sql: $axl_sql\n" if ( $DEBUG==1); 32my $data = SOAP:ata->name( "sql" => $axl_sql ); 33my $res = $cm->executeSQLQuery( $data ); 34unless ($res->fault) { 35 $Data:umper::Indent = 3; 36 print Dumper($res->paramsall()) if ( $DEBUG==1); 37} else { 38 $error_text = $res->faultcode.' '.$res->faultstring."\n"; 39 print $error_text; 40} BR Michael
