cdnadmin
Community Member
This document was generated from CDN thread
Created by: David Roberts on 05-02-2010 01:24:48 AM
 We are analyzing the cause codes from a customer site and seems there is a code of 10 for origCause_location.  When I refer to the CDR document, I don't see any mapping of code 10 to a message.  Can someone provide me with the proper message?
Subject: RE: Cause Code 10?
Replied by: Anitha V on 05-02-2010 05:19:11 AM
Hi David,
Could you please let me know which callManager version your customer is using?
Also, could you please send the corresponding CDR in question?
Thanks and Regards,
Anitha
Replied by: Anitha V on 08-02-2010 05:49:46 AM
Hi David,
Looks like "origCause_location" iself is not a cause code. The cause code is the origCause_value/destCause_value.
The origCause_location field is a field indicated in the ISDN release message. The internal values from code for the cause_location are:
const NATURAL PRIV_NET_LOCAL = 1;
const NATURAL PUB_NET_LOCAL = 2;
const NATURAL TRANSIT_NET = 3;
const NATURAL PUB_NET_REMOTE = 4;
const NATURAL PRIV_NET_REMOTE = 5;
const NATURAL INTL_NET = 7;
const NATURAL NET_BEYOND_INTERWORK_PT = 10;
Hope this helps.
Thanks and Regards,
Anitha
Replied by: David Roberts on 10-02-2010 03:58:36 AM
hi, this is helpful however the CDR manual seems to state that orig/destCause_location can have values 1-15 and you show just 1-10.  I assume there's a mistake in the CDR manual since it makes no mention of these ISDN codes.
Do you have any place which helps explain which each of these mean?
