cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Drilon jahiri on 14-01-2012 11:14:17 AM
Hi one another time.I hope this time someone is goint to help me because I have more then 2 weeks trying to calculate the duratioon of a call in CDR logs but still without an excat result.I have CDRs in my FTP server and what I want is to calculate the duration of a call.I have read all CISCO documentation about CDRs and everything that has to do with CDRs.
I need a little help please.
When I make a call tthen in CDR that call is saved at minimum in two legs: one outgoin leg(originate) and one incoming leng(answer).In every all legs there is a setup time,connect time and disconnect time and these atributes aren`t in every leg the same.I want to know hot to derive the duration of a call.When does a call start?
Should I take the connect and disconnect time of answer leg or orignate leg.
in atachement is a CDR file in compact version and please please...please somenone help me beacause I need this to make an application for my thesis.
Thank YOu for reading this post!
Subject: RE: CDR Duration of a call
Replied by: Raghavendra Gutty Veeranagappa on 15-01-2012 04:44:30 AM
Hi Drilon,
please try to post your query in below forum you might get an answer.
http://developer.cisco.com/web/sxml/forums/-/message_boards?_19_mbCategoryId=1964549
Raghavendra
Replied by: Drilon jahiri on 15-01-2012 06:41:12 AM
Hi Drilon,
Raghavendra
OK Thank YOu...I will try this and I hope someone is going to help me.
