jeesemon.91
Level 2
Level 2
 Problem Description
         On first time boot-up  VCS appliance CE1100 system stuck at particular level PFB.
 Resolution
       For remote access / access to the serial port, you must enable Serial over LAN (SoL) on the CIMC. You may enable it following the below steps
Toggle Navigation --> Compute --> Remote Management --> Virtual KVM --> Enable Serial over LAN
    Then system might go for a reboot, the terminal emulator program on the PC will display the Cisco Expressway’s startup information. After approximately four minutes you will get the login prompt. Now configure application IP & other details
  I believe this article helped you. please respond
