cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jesper Myrin on 10-02-2011 12:28:33 PM
I searched on the forum and find a message that Tandberg doesn't support this from June last year. Has there been any change regarding this? Perhaps this is not poosible on the C-codecs? I just wanna bes sure when I come back to the customer.
Jesper
Subject: RE: CEC (Consumer Electronic Protocol)
Replied by: Roger Boe on 10-02-2011 04:52:53 PM
Hi Jesper,
We have actually done some work on this an plan to support it officially in an upcoming release. I don't have the dates yet, but most likely TC4.2. The support will simply be for setting the TV monitor in and out of standby.
Best regards
Roger
Replied by: Justin Ferello on 21-07-2011 09:18:06 PM
FYI, TC4.2 was released today and it now supports CEC!
Support for CEC (Consumer Electronics Control)
The HDMI outputs now support Consumer Electronics Control (CEC). When set to on (default is off),
and the monitor connected to the HDMI output is CEC compatible and CEC is configured, the system
will use CEC to set the monitor in standby when the system enters standby. Likewise the system will
wake up the monitor when the system wakes up from standby. Please note that the different
manufacturers uses different marketing names for CEC: Anynet+ (Samsung); Aquos Link (Sharp);
BRAVIA Sync (Sony); HDMI-CEC (Hitachi); Kuro Link (Pioneer); CE-Link and Regza Link (Toshiba);
RIHD (Remote Interactive over HDMI) (Onkyo); SimpLink (LG); HDAVI Control, EZ-Sync, VIERA Link
(Panasonic); EasyLink (Philips); and NetCommand for HDMI (Mitsubishi).
Justin
Replied by: Marko Laurits on 02-01-2012 05:43:49 PM
Happy new year!
Justin Ferello:
We have used CEC successfully with Sony and Samsung TVs.
But we have had no success with LG TVs. It looks like LG TV does not recognize Tandberg C20.
Has anybody got it work?
Is there anything that should be specifically configured?
Question 2:
Is there any hope DVI-I output will also support CEC?
If a customer wishes to use C40 with two TVs then both TVs could be connected through HDMI inputs.
I mean - would the hardware of DVI-I output port enable CEC support similarly to HDMI?
Marko
