cdnadmin
Community Member
This document was generated from CDN thread
Created by: JAMES DEPHILLIP II on 15-02-2013 02:14:30 PM
Is it possible to push XML to the phone that has a refresh interval to clear the screen similar to using the header refresh capability in a http get?
Subject: RE: CGI Execute Question
Replied by: David Staudt on 15-02-2013 02:41:46 PM
If I understand your question correctly the answer is no, but the workaround is to use CiscoIPPhoneExecute to get the phone to make a URL request, which returns something like a CiscoIPPhoneText object with a Refresh header on it.
Replied by: JAMES DEPHILLIP II on 15-02-2013 03:56:54 PM
That is what I thought just wanted to make sure I wasn't missing something.
Thanks!
David Staudt:
