cdnadmin
Community Member
This document was generated from CDN thread
Created by: deniz caglar on 04-01-2013 07:30:11 AM
Is it possible to change the ActivityLog's path which is defult in C:\Cisco\CVP\VXMLServer\applications\IVR_ApplicationName\logs ?
I can change the max file size or purge setting in the Properties, General Settings, ActivityLog, Edit window.
So can i give any other path for ActivityLogs such as like D:\Logs ?
Deniz
Subject: RE: New Message from deniz caglar in Customer Voice Portal (CVP) - General
Replied by: Hemal Mehta on 04-01-2013 07:34:12 AM
I do not believe there is way to do that.  It’s a default path. You can always create a link to that such that logs also are available elsewhere.
Hemal
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Friday, January 04, 2013 7:30 AM
To: [email protected]
Subject: New Message from deniz caglar in Customer Voice Portal (CVP) - General Discussion - All Versions: Changing ActivityLog's path
deniz caglar has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- Hi,
Is it possible to change the ActivityLog's path which is defult in C:\Cisco\CVP\VXMLServer\applications\IVR_ApplicationName\logs<file:///\\10.231.16.145\c$\Cisco\CVP\VXMLServer\applications\IVR_ApplicationName\logs> ?
Deniz
To respond to this post, please click the following link: http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/9911751 or simply reply to this email.
