cdnadmin
Community Member
This document was generated from CDN thread
Created by: Janine Graves on 03-03-2009 02:07:08 PM
Is it possible to use  Chinese Unicode for the TTS text within Studio - i.e.,can
one enter Chinese Characters or Pin Yin into these fields assuming one has the corresponding Windows language support?
Subject: RE: Chinese Unicode
Replied by: Tieying Xuan on 04-03-2009 02:57:30 PM
Sure. You can input Chinese words in CVP Call Studio directly. I have tried this by myself. It works.
There is some limitation in using Chinese symbols in Call Studio. I'll update you later.
Replied by: Tieying Xuan on 05-03-2009 08:17:16 AM
First of all Chinese TTS/ASR is required. Nuance provides Chinese language packages in its network. It works with CVP/Cisco Gateway. But the TTS server don't accept "zh-CN" language tag quick well. Some manual configure in file and registry is needed. There are some Chinese local TTS vendors you could choose also.
In Call Studio project general setting, there is no "zh-CN" language to select in the frop down list. But you can input it manually. The encoding should be "UTF-8"
You can imput Chinese symbols in Call Studio audio prompt. But don't use "Say it smart" function. CVP will interpret data according to user selected type. But there is no built-in Chinese support in CVP element. So the data will be interpreted as English by default. There are 2 ways to resolve it.
 1. Write your elements based CVP fundamental Java API
 2. Some TTS engine will support <say-as> tag with VXML or SSML. You can input synthesis markup in prompt entry directly
There are some built in ASR grammar in Call Studio elements. It might won't work with Chinese TTS. For example, if you use hotlink in some elements, it will generate grammer with English words "help". If you want to use TTS only without ASR, you could ignore these issues. Or you have to round them.
In one words, CVP Call Studio hasn't fully tested with Chinese. But it works well in most of cases.
