sid_vc99
 Hi there we are running into a license expiration issue on Unity . We would like to know if this is just a matter of buying additional licenses or moving licenses around.. not sure why the Enhanced (10.x) is not showing up as a unity license connections
CUWL Standard (10.x)Unified CM43
Enhanced (10.x)Unified CM41
Enhanced Plus (10.x)Unified CM1
Essential (10.x)Unified CM20
  105
Basic Messaging (10.x)Unity Connection20
CUWL Standard Messaging (10.x)Unity Connection43
SpeechConnect Port (10.x)Unity Connection5
Ted S
Assuming what you have shown, the top being from Communications Manager and bottom chart is from Unity Connection
CUWL license includes voicemail whereas enhanced licensing does not, therefore you will need to buy additional licenses for Unity Connection.
sid_vc99
Correct . Thank you so much for the confirmation
