cdnadmin
Community Member
This document was generated from CDN thread
Created by: Chikeobi Njaka on 26-04-2013 03:38:10 AM
Dear Gang; I get this error when executing any AXL:
            soapenv:Server       java.lang.NoClassDefFoundError: Could not initialize class schemaorg_apache_xmlbeans.system.s1A261E697A233A368DB352D8413ED88F.TypeSystemHolder               Any ideas?
Subject: RE: Class Not Found
Replied by: David Staudt on 26-04-2013 12:50:22 PM
Can you browse to the AXL service URL on your host?  E.g.: https://ucmhost:8443/axl/
You should see
Cisco CallManager: AXL Web Service
The AXL Web Service is working and accepting requests. Use HTTP POST to send a request.
If not, then its possible the AXL service has not been started on UCM
Otherwise looking into the AXL service logs (via the RTMT tool) may give some insight
Subject: RE: New Message from David Staudt in AXL Developer - Administration XML Que
Replied by: Chikeobi Njaka on 26-04-2013 04:50:07 PM
Hi David,
Yup, I got that… yet no workie-workie…. Can you point me to where I can get information about debugging this using RTMT?
Thanks.
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Friday, April 26, 2013 10:51 AM
To: [email protected]
Subject: New Message from David Staudt in AXL Developer - Administration XML Questions: RE: Class Not Found
David Staudt has created a new message in the forum "Administration XML Questions": -------------------------------------------------------------- Can you browse to the AXL service URL on your host?  E.g.: https://ucmhost:8443/axl/
You should see
To respond to this post, please click the following link: http://developer.cisco.com/web/axl-developer/forums/-/message_boards/view_message/14708336 or simply reply to this email.
