cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 21-12-2005 07:42:45 PM
In a custom Audium action I'm trying to execute the following code in order to get an InputStream from a file that I've placed in the java/application/classes folder:
InputStream inStream = Thread.currentThread().getContextClassLoader().getResourceAsStream("credentialing_codes.xml");
No matter what I seem to do I'm getting a null exception when I try to access that InputStream. Am I grabbing the right classloader from my app?
Subject: RE: ClassLoader Issues?
Replied by: Vance Vagell on 21-12-2005 10:52:57 PM
Hi Rich,
The Audium Java API includes a mechanism by which to resolve the path of files such as your XML file, without having to hard-code a path. We recommend that you use the getApplicationDirectory() method of the APIBase class, which will return your application's actual path, such as:
/usr/local/Audium/applications/MyApp/
Using this approach, you could store your XML file in the data/misc folder, which is the intended location for such assets. For additional information about this method, please refer to the Audium Java API Javadocs.
Vance
