cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mahesh Sambandam on 01-10-2013 12:40:52 AM
Hi all,
I am new to AXL Developer Programming.
My task is to create automation to update cmc code in cucm database.
Where i can find the API documentation for CMC . I am searching for past one week i didn't find any.
or, UDDI regarding CMC.
Subject: RE: Client Matter Code
Replied by: David Staudt on 01-10-2013 11:42:02 AM
Assuming CMC = Client Matter code, I believe the add/update/removeCmcInfo requests may be what you are looking for:
http://developer.cisco.com/axl/Files/AXLSoap_addCmcInfo.html#Link97
Replied by: Mahesh Sambandam on 02-10-2013 10:26:46 PM
Hi david,
Thanks for your reply.
But what i am now exactly looking is i have  coding of all API"s
In UpdateCmcInfoReq API there are four variables "uuid,code,newcode,description"
I need to explanation of those variables like what is "uuid" and what is difference between "code" and "new code" .
Where i find those explanation documentation.
Replied by: David Staudt on 03-10-2013 03:19:35 PM
Re updateCmcInfo:
- The CMC record to update can be specified by providing either the 'uuid' (the record's database unique key, a GUID value, often named 'pkid' in the UCM database) or by the actual CMC code itself, i.e. a sequence of numeric characters (string.)
- The record can be updated to change the actual code by specifying the <newCode> field.  The resulting record will have the same uuid, but a different code value:
 1<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
 2   <soapenv:Header/>
 3   <soapenv:Body>
 4      <ns:updateCmcInfo sequence="1">
 5         <code>1234</code>
 6         <newCode>12345</newCode>
 7         <description>newDescription</description>
 8      </ns:updateCmcInfo>
 9   </soapenv:Body>
10</soapenv:Envelope>
11-------------------------------
12<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
13   <soapenv:Body>
14      <ns:updateCmcInfoResponse sequence="1" xmlns:ns="http://www.cisco.com/AXL/API/9.1">
15         <return>{2CC311E6-CB70-3B43-1852-EE6AC904FEE9}</return>
16      </ns:updateCmcInfoResponse>
17   </soapenv:Body>
18</soapenv:Envelope>
Replied by: Mahesh Sambandam on 03-10-2013 10:21:26 PM
Thanks David for detail explanantion.
You help me a lot.
If I have further more queries i will post it here.
Thanks again
Replied by: Mahesh Sambandam on 03-10-2013 11:59:17 PM
Hey David,
In ListCmcInfoReq API there are four variables "searchCriteria","ReturnedTags","skip","first"
Initially i have a doubt in CMC Table. How many columns are there in that table ? Can you list me the details.
If i need to get all the CMC codes and description in that table. How can i do it.
Whether all the four parameters are madantory ? To fetch the values from database.
