cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jayakrishnan Rajagopal on 18-01-2012 11:21:57 AM
We have a deployment where the EX90 and C60 Codec are placed in different networks. And we are having a currently Tandberg VCS Expressway. I know that we can register the EX90 as one endpoint in the VCS. But there is no option to reigster the C60 codec. Here we would like to have a call from C60 codec to EX90. But since I am not able to do the registration on VCS, I would like to know so is this possible only throught TCS or else VCS itself can do this . If VCS Express can do this, can I know what is the procedure ?.
JK
Subject: RE: Codec C60 calling Ex90 using TCS or VCS
Replied by: Spenser P on 18-01-2012 11:50:28 AM
Hi jayakrishnan,
Both Ex90 and C60 can register in VCS. and make call between those two.
You need to enable H.323 and SIP services in the device and make the call setup mode as Gatekeeper.
Replied by: Jayakrishnan Rajagopal on 13-02-2012 08:46:17 AM
Thank you for the answers. When i see the VCS expressway, i can see the option for registering the EX90 , E20 etc. But i cannot see any place for registering the Codec C60.  Is there any procedure to do this ? .Can i know where can i find the documnt for this.?
JK
Replied by: Enrico Conedera on 23-01-2012 12:28:50 AM
Jayakrishnan KR:
JK
Just to add to the other answer that was provided -
The VCS Expressway is *designed* to allow endpoints from many different networks to register to it.  It should be placed in a public IP space (with appropriate protection for management ports).  Then any EX, C Series, MX, MXP etc can register to it thru their local firewall, with secure and simple firewall rules.
enrico
