cdnadmin
Community Member
Subject: Re: New Message from WESLEY PHILLIPS in Voice Gateway API (VGAPI) - TCL-API
Replied by: LEON MCCALLA on 04-08-2011 04:40:12 PM
I asked this question in 2003 and they told me it would be a lot of work and that I needed to make a business case.  Because of this I have to filter all IP-IVR to G729. in rare situations where G723 is needed I use an prefix to select a different dial-peer which pulls different files.
this is much like the question of asking to be able to select a target IP from within TCL. Again ¿provide a business case¿. unless a large company like ATT or Bank of America wants something it won¿t become a new feature. Thinking like this is very short sighted.
Leon
Sent: Thursday, August 04, 2011 2:39 PM
To: [email protected]
Subject: New Message from WESLEY PHILLIPS in Voice Gateway API (VGAPI) - TCL-API: codec detection
WESLEY PHILLIPS has created a new message in the forum "TCL-API":
Is there a way to identify the codec that was negotiated for the leg_incoming leg? I am having a problem getting a prompt to play out on the inbound leg because of codec mismatches. I would like to be able to pull the codec for the inbound leg from an infotag, and then do either a switch or if/else statement to point a media play command to different files based on codec.
Wes
To respond to this post, please click the following link:
<http://developer.cisco.com/web/vgapi/forums/-/message_boards/view_message/4322461>
or simply reply to this email.
This document was generated from CDN thread
Created by: WESLEY PHILLIPS on 04-08-2011 02:39:52 PM
Wes
Subject: RE: codec detection
Replied by: WESLEY PHILLIPS on 04-08-2011 03:54:20 PM
I have also tried this:
set testa [infotag get leg_proto_headers leg_incoming]
    puts "\n\n\ntesta=$testa\n\n"
set testb [infotag get evt_proto_headers]
    puts "\n\n\ntesta=$testb\n\n"
but these both came back with an empty string:
Aug  4 17:48:22.871: //4551//TCL :/tcl_InfotagObjCmd:  infotag get leg_proto_headers leg_incoming
Aug  4 17:48:22.871: //4551//TCL :/tcl_InfotagGetObjCmd: infotag get leg_proto_headers leg_incoming
Aug  4 17:48:22.871: //4551//AFW_:/vtr_lg_proto_headers: argc 3 argindex 2
Aug  4 17:48:22.871: //4551//TCL :/tcl_PutsObjCmd:
testa=
Aug  4 17:48:22.871:
Aug  4 17:48:22.871: //4551//TCL :/tcl_InfotagObjCmd:  infotag get evt_proto_headers
Aug  4 17:48:22.871: //4551//TCL :/tcl_InfotagGetObjCmd: infotag get evt_proto_headers
Aug  4 17:48:22.871: //4551//AFW_:/vtr_ev_proto_headers: argc 2 argindex 2
testb=
Aug  4 17:48:22.871:
and according to the documentation, if I do not specify an attribute in the infotag get command, all attributes are supposed to be returned in a single string seperated by the "&" character.
Replied by: Yaw-Ming Chen on 04-08-2011 04:03:35 PM
I don't think there is way Tcl API can detect what codec is negotiated.
Thanks !
Replied by: WESLEY PHILLIPS on 04-08-2011 04:47:22 PM
I am thinking that I might be able to "cheat" this one. If this fails:
media play leg_incoming en_prompt.au
because the negotiated codec is g729, and the file is g711, then I should be able to do something like this(assuming that the files are in the proper formats):
media play leg_incoming en_prompt_g729.au
media play leg_incoming en_prompt_g711.au
Essentially one of the two will always fail and the other one will always play. If I have a codec class on the dial peer that has three preferecnces, then I would have to have three audio prompts, instead of two. My experience is that as soon as the TCL script fails a media play option because of codec mismatch, it simply moves on to the next command, so this should theoretically work.....
Wes
