cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 16-04-2007 07:37:01 PM
I have two classes with same name but in different package. I put them in Server\common\classes folder
Server
|__Common
|_____classes
|_______P1
|_________class1.class
|_______P2
Tomcat throws an error when starts up and fails to load any application.
Loading application 'test'...
      • An error occurred while loading application 'test'. The error was: There was a problem loading classes from AUDIUM_HOME/common: java.lang.NoClassDefFoundError: P2/class1 (wrong name: P1/class1). This application will be unavailable until the problem is fixed. Note that all voice applications should experience the same error. ***
Subject: RE: Common classes with same name
Replied by: null on 19-04-2007 01:05:17 PM
Hello Luong,
We have attempted to reproduce your error. We duplicated a class with the same name but in a different package as you described and deployed both packages to the common\classes directory. One test application referenced the class from one package. Another test application referenced the second class from the other package. Tomcat is started; the server did not throw any error, and we were able to call into both test applications. We were not able to reproduce your error.
Please provide more detail regarding your classes and your test application that failed to be loaded.
Tam
Replied by: null on 19-04-2007 03:28:19 PM
Hello Luong,
The second class with the same class name deployed to the directory common\classes\P2 has an incorrect package declaration, hence the error message â¿¿java.lang.NoClassDefFoundError: P2/class1 (wrong name: P1/class1)â¿¿.
Correct the package declaration (P2 not P1) and deploy the compiled class to the proper directory.
Tam
