Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Phil Bridges on 01-09-2010 04:28:29 PM Is there a helpfile anywhere for Compositor? I'm trying to set up scenarios based on 3 external participants - do I actually have to have 3 external participants online in order to set up these windows?
Subject: RE: Compositor Manual / Helpfile? Replied by: Phil Bridges on 01-09-2010 08:41:09 PM It appears that you have to connect to three participants to set windows up for them. Is this correct?
On an added note, *once* I got the API output to work. Since that one time, when I try to get the XML API info, it opens a blank window and nothing is populated. Any suggestions on how to fix this?
Subject: RE: Compositor Manual / Helpfile? Replied by: Jonas Tysso on 02-09-2010 09:19:39 AM Hi Phil,
Phil Bridges:
I'm afraid that's how it is with this demo application.
Phil Bridges:
The XML API info will only display changes that you perform after the window is open. So you will have to open this window before you adjust your video layouts.
