This document was generated from CDN thread
Created by: null on 05-12-2003 03:43:10 PM
I need my Confirmation Audio for a number capture to say, "I heard the account number is VALUE". how do I concatenate these two? I tried concatenating using a variable too.
Subject: RE: Concatenate Text and variable data
Replied by: Michael Bochynski on 05-12-2003 08:10:41 PM
The task can be achieved using Say-It-Smart option.
Go to the Audio Tab for the element which you are using to confirm the number. In the audio item use TTS prompt ("I heard the account number is ") or your custom audio file (providing URI). Then add another audio item in the same group. Right-click on this group and choose "Add Audio Item". For the new audio item choose "Say It Smart" option in the configuration panel and set the following options:
From Element: <name-of-your-number-capturing-element>
Element Data: value
Type: Number
Input Format: Standard
Output Format: Standard Number
Please bear in mind, that the configuration may slighty differ depending on what element is used for confirmation. Additionaly, depending on the voice element used (custom or Audium), the element data name (in this case "value") may differ, since it is to the voice element developer to define.
This solution will say the both the prompt and the captured number.
You can find the detailed description of all the options in the UserGuide.pdf, section The Audio Tab (pages 47-55).
Hope this will help,
Michael
Subject: Thanks!
Replied by: null on 05-12-2003 08:31:05 PM
Thanks Michael! This helps!
Cheers!
