Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Fabien Damien on 16-01-2009 02:12:15 PM Hi all,
I'm building a voice application on CVP studio, i need to include an element to get the ANI (calling number) and compare its first 7 digits to a string; if they're equal the user will be directed to "fixed number" decision, else to a "mobile number" decision. I know i should use a configurable decision element,with a java class but i'm not sure about the java code.I have no experience in JAVA. If anyone can help develop the code. Thanks and regards,
Subject: Re: Configurable Decision Element Replied by: Janine Graves on 16-01-2009 02:44:45 PM Here, you could actually just use a regular decision element and use the Decision Editor.
In the Deicision Editor compare the ANI (either from CallData.ANI or if ICM passed it in, it will be stored in Session Data somewhere) and use the comparison 'Starts With' and then compare with a Constant String).
Subject: Re: Configurable Decision Element Replied by: Fabien Damien on 16-01-2009 03:08:44 PM Thanks Janine this was very helpful
