Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Christopher LeBlanc on 08-08-2008 01:13:17 PM At the bottom is text from the mailer. Here is how to configure a PRI T1 on IOS.
Regards, -Chris
PRI is signaling that IOS uses to make or recieve phone calls where it uses 23 T1 channels per T1 card plus one D channel (or data channel).
The D channel is used to send the Caller ID and other information to the in-bound GW. This is called 'out-of-band' signaling. Out-of-band signaling occurs when the data is recieved by IOS via a Data channel.
The following configuration is needed for the PRI T1 controller:
For each PRI controller, you also need to define an Interface as follows:
interface Serial6/0:23 no ip address ip mroute-cache no snmp trap link-status isdn switch-type primary-5ess isdn incoming-voice modem no fair-queue no cdp enable
When you create the configuration for the controller T1 above, IOS will also create this entry for you. This is the voice port that you will either listen in on or send out calls to:
voice-port 6/0
sorry .. incoming call using PRI
Rafi
----- From: Rafi Shaltiel (rshaltie) Sent: Thursday, August 07, 2008 11:22 PM To: ask-cvp-support(mailer list) Subject: AS5350 config example
Can someone please share with me "sh run" of working AS5350XM with CVP (incoming calls via SIP) ? I need it for a partner that has issues with the configuration
Also - what is the recommended IOS for AS5350 VXML w/CVP (currently running 12.4(20T))
Thanks Rafi
Edited by: Christopher LeBlanc on Aug 8, 2008 9:13 AM
Edited by: Christopher LeBlanc on Aug 8, 2008 9:22 AM
Subject: Re: Configuring PRI Replied by: Christopher LeBlanc on 08-08-2008 02:14:52 PM Hi Rafi, Please respond here. We are moving people off the mailer to the forums. Your question is very open ended. CVP can be configured with many different deployment models using H323 or SIP. A GW can be Ingress, VXML or both. The recommended configuration for IOS with CVP is in the CVP Config and Admin Guide. We do not publish how to configure T1 lines because they are usually configured by network engineers that work for the partners or customer and CVP is an IVR.
If you have a specific question about certain configurations, I can answer them or I can point to you recommended configuration for CVP. But the configuration is hardware independant. The config applies for all versions of IOS.
What exatly is your issue? Listing a 'show run' would most likely not solve your issue since each GW (outside of CVP config) will be configured differently at each customer depending on the customer's need for that GW.
Regards, -Chris ----- Hi Chris,
Thanks a lot.
I was looking for the entire "sh run" that will include the application configuration, dial-peers etc.. Can you please provide me such for 5350 vxml GW working with PRI and CVP
