cdnadmin
Community Member
This document was generated from CDN thread
Created by: Daniel Hammett on 12-11-2009 10:24:49 PM
Is there any way to have the corporate directory pull from an existing SQL database.  I have found the example coding for LDAP in the SDK but I cannot seem to find anything about whether it is even possible to do this.  If anyone knows of any code examples it would be much appreciated.
Subject: RE: Corporate Directory from SQL
Replied by: David Staudt on 13-11-2009 12:18:48 AM
Well, this is certainly posible, but the implementation depends entirely on your web server environment, how you want to connect to the DB, the DB itself, etc.  All of that stuff is beyond the scope of the phone API support here, though if you can describe your specifics someone in the community may have some advice.
Subject: SQL > LDAP > Directory: Corporate Directory from SQL
Replied by: Brian Lavallee on 27-11-2009 04:04:56 AM
If you are not using LDAP for anything else, you may want look at using LDAP with SQL.  While adds another layer to the mix, both LDAP/SQL and Directory/LDAP are documented.
