Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Richard Rhinehart on 22-05-2011 02:51:08 PM Hello, I have a deployed studio application but do not have the project files. What would be the easiest way to "import" a deployed version back into call studio? I was hoping this could be done through the UI but it doesn't appear to have that functionality or I haven't found it. Thanks
Subject: Re: New Message from Richard Rhinehart in Customer Voice Portal (CVP) - Gen Replied by: Janine Graves on 22-05-2011 10:57:39 PM No easy way to go from VxmlServer app back to Studio. You can 'work out' what the callflow was from the callflow.xml file and then 'work out' the element configurations from the configurations folder, each element is listed.
On 5/22/2011 2:51 PM, Cisco Developer Community Forums wrote: > Richard Rhinehart has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > Hello, >  > I have a deployed studio application but do not have the project > files. What would be the easiest way to "import" a deployed version > back into call studio? I was hoping this could be done through the UI > but it doesn't appear to have that functionality or I haven't found it. >  > Thanks > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/3927274> > > or simply reply to this email.
-- Janine Graves
Subject: RE: New Message from Janine Graves in Customer Voice Portal (CVP) - General Replied by: Hemal Mehta on 23-05-2011 08:30:40 AM That is correct. Actually should not be too hard to develop a tool that can construct this based on the deployed project. Cisco should consider providing this functionality in new versions. Hemal ________________________________ From: Cisco Developer Community Forums [[email protected]] Sent: Sunday, May 22, 2011 9:57 PM To: [email protected] Subject: New Message from Janine Graves in Customer Voice Portal (CVP) - General Discussion - All Versions: Re: New Message from Richard Rhinehart in Customer Voice Portal (CVP) - Gen
Janine Graves has created a new message in the forum "General Discussion - All Versions":
-------------------------------------------------------------- No easy way to go from VxmlServer app back to Studio. You can 'work out' what the callflow was from the callflow.xml file and then 'work out' the element configurations from the configurations folder, each element is listed.
-- Janine Graves -- To respond to this post, please click the following link:
