RajaSaravanan
Level 2
Level 2
from zeep import Client
import requests
from requests.auth import HTTPBasicAuth
from zeep import Client, Settings, Plugin, xsd
from zeep.transports import Transport
from zeep.exceptions import Fault
import sys
import urllib3
import os
from lxml import etree as ET
from bs4 import BeautifulSoup as bs
import re
#from dotenv import load_dotenv
#load_dotenv()
#userdn = input("Please enter user extension:")
#fname = input("Please enter first name:")
#lname = input("Please enter last name:")
#fullname = fname + lname
#useremail = input("Please enter email:")
with open("PATH/bulkload.txt","r") as inp:
data = inp.read().split('\n')
bdirn = len(data)
print(bdirn)
#Func To Add End User
def createenduser(enduserid, fname, lname, udevname, useremail):
print(useremail)
end_user = {
'firstName':fname,
'displayName':enduserid,
'lastName':lname,
'userid':enduserid,
'password':'123654',
'pin':'123654',
'mailid': useremail,
'userLocale':'English United States',
'associatedGroups': {
'userGroup': [
'name': 'Your Standard End Users',
'userRoles': {
'userRole': [
'Standard CCM End Users',
'Standard CCMUSER Administration'
'Standard CTI Enabled'
'enableCti':'true',
'presenceGroupName':'Standard Presence group',
'enableMobility':'false',
'enableMobileVoiceAccess':'false',
'maxDeskPickupWaitTime':'10000',
'remoteDestinationLimit':'4',
'enableEmcc':'true',
'homeCluster':'true',
'imAndPresenceEnable':'true',
'serviceProfile':'Your UC Profile',
with client.settings(raw_response=True):
resulteu = (service.getUser( userid = enduserid ))
mytxteu = (resulteu.text)
phoneitereu = 0
e = 0
#print(mytxteu)
soup = bs(mytxteu, 'html.parser')
#print(soup.find_all('pattern'))
print(soup.find_all('userid'))
mydneu = (soup.find_all('userid'))
#Check for Existing user and associated devices
if (len(mydneu) == 0 😞
try:
respeu = service.addUser( end_user )
#print( '\naddUser response:\n' )
except Fault as err:
print( f'Zeep error: addUser: { err }' )
sys.exit( 1 )
print( respeu,'\n' )
else:
print('User Already Exists')
#FUNC to Update End User
def updateenduser(enduserid,fname,lname,devices,myphoneProfiles,useremail,extn):
try:
resp = service.updateUser(
userid= enduserid,
pin = '123654',
associatedDevices = devices,
phoneProfiles = myphoneProfiles,
selfService = extn,
enableUserToHostConferenceNow = True,
enableCti = True,
presenceGroupName = 'Standard Presence group',
enableMobility = False,
enableMobileVoiceAccess = False,
maxDeskPickupWaitTime = 10000,
remoteDestinationLimit = 4,
enableEmcc = True,
homeCluster = True,
imAndPresenceEnable = True,
serviceProfile = 'Your UC Profile',
primaryExtension = {'pattern' :extn,
'routePartitionName' :'Your_Phones_PRT'},
associatedGroups = {
'userGroup': [
'userRoles': {
'userRole': [
print( f'Zeep error: updateUser: { err }' )
sys.exit( 1 )
print( '\nupdateUser response:\n' )
print( resp,'\n' )
#FUNC to Add DIrectory Number
def adduserline(fullname, fname, lname, udevname, useremail, userdn, usercss):
print('The Current User Dn is',userdn)
print(fullname)
print(fname)
print(lname)
print(udevname)
print(useremail)
print(usercss)
line = {
'pattern':userdn,
'description':fullname,
'usage':'Device',
'routePartitionName':'Your_Phones_PRT',
'aarKeepCallHistory':'true',
'aarVoiceMailEnabled':'false',
'callForwardAll':{
'forwardToVoiceMail':'false',
'callingSearchSpaceName':'Your_Internal_CSS'
'callForwardBusy':{
'forwardToVoiceMail':'true',
'callForwardBusyInt':{
'callForwardNoAnswer':{
'callForwardNoAnswerInt':{
'callForwardNoCoverage':{
'callForwardNoCoverageInt':{
'callForwardOnFailure':{
'callForwardAlternateParty':{
'callForwardNotRegistered':{
'callForwardNotRegisteredInt':{
#'callPickupGroupName':'xsd.SkipValue',
'autoAnswer':'Auto Answer Off',
'networkHoldMohAudioSourceId':'1',
'userHoldMohAudioSourceId':'1',
'callingIdPresentationWhenDiverted':'Default',
'alertingName':fullname,
'asciiAlertingName':fullname,
'shareLineAppearanceCssName':usercss,
'voiceMailProfileName':'Your_VM_Profile',
'patternPrecedence':'Default',
'releaseClause':'No Error',
'allowCtiControlFlag':'true',
'rejectAnonymousCall':'false',
'patternUrgency':'false',
'cfaCssPolicy':'Use System Default',
'partyEntranceTone':'Default',
'useEnterpriseAltNum':'false',
'useE164AltNum':'false',
'active':'true',
# Execute the addline request
result = (service.listLine({ 'pattern' : userdn}, returnedTags={'description': '','pattern':'','alertingName':''}))
mytxt = (result.text)
print(mytxt)
soup = bs(mytxt, 'html.parser')
print(soup.find_all('pattern') )
print('\n')
print(soup.find_all('line'))
print('\n')
mydn = (soup.find_all('pattern'))
print(mydn)
print('the current dn lenght is',len(mydn))
ename =str(soup.find_all('alertingname'))
#print('Printing org name \n')
#print(ename)
orgusrn = ename.replace('[<alertingname>','').replace('</alertingname>]','')
#print(orgusrn)
if (len(mydn) == 0 😞
try:
print('trying to add line')
resp = service.addLine(line)
print('\naddline response \n')
print(resp,'\n')
print(f'Zeep error: addLine: { err }')
sys.exit(1)
else:
try:
print('trying update line')
print( f'Zeep error: updateLine: { err }' )
sys.exit(1)
#FUNC to add phone
def adduserphone(enduserid, fullname, fname, lname, udevname, useremail, devcss):
print('the current user id on the phone', fullname)
phone = {
'name':udevname,
'description':enduserid,
'product':'Cisco Unified Client Services Framework',
'class':'Phone',
'protocol':'SIP',
'protocolSide':'User',
'callingSearchSpaceName':devcss,
'devicePoolName':'Your_DP',
'commonPhoneConfigName':'Standard Common Phone Profile',
'locationName':'Your_Location',
'mediaResourceListName':'Your_MRGL',
'useTrustedRelayPoint': 'Default',
'builtInBridgeStatus': 'Default',
'packetCaptureMode': 'None',
'deviceMobilityMode': 'Default',
'certificateOperation':'No Pending Operation',
'phoneTemplateName':'Standard Client Services Framework',
'enableExtensionMobility':'true',
'ownerUserName':enduserid,
'unattendedPort':'false',
'requireDtmfReception':'false',
'rfc2833Disabled':'false',
'dndStatus':'false',
'isActive':'true',
'isDualMode':'false',
'AllowPresentationSharingUsingBfcp':'false',
'requireOffPremiseLocation':'false',
'allowiXApplicableMedia':'false',
'useDevicePoolCgpnIngressDN':'true',
'enableCallRoutingToRdWhenNoneIsActive':'false',
'allowMraMode':'false',
# Execute the addPhone request
result = (service.getPhone( name = udevname ))
phoneiter = 0
i = 0
#print(mytxt)
print(soup.find_all('name'))
mydn = (soup.find_all('name'))
resp = service.addPhone( phone )
mydevicej = udevname
print('not found')
print( '\naddPhone response:\n' )
print( resp,'\n' )
else:
print( 'Device Found' )
def updatemulti(devlines,udevname):
try:
print(udevname)
print(devlines)
resp = service.updatePhone(name = udevname,
lines = devlines)
print( '\nupdatePhone response:\n' )
print( resp,'\n' )
print( f'Zeep error: updatePhone: { err }' )
sys.exit( 1 )
with open("PATH/cred.txt","r") as f:
mylist = f.read().splitlines()
USERNAME=mylist[0]
PASSWORD=mylist[1]
ccmip=mylist[2]
f.close()
#client = Client(wsdl)
# Change to true to enable output of request/response headers and XML
DEBUG = False
# The WSDL is a local file in the working directory, see README
WSDL_FILE = 'PATH/schema/AXLAPI.wsdl'
# This class lets you view the incoming and outgoing http headers and XML
# The first step is to create a SOAP client session
session = requests.Session()
# We avoid certificate verification by default
# And disable insecure request warnings to keep the output clear
session.verify = False
urllib3.disable_warnings( urllib3.exceptions.InsecureRequestWarning )
# Add Basic Auth credentials
session.auth = HTTPBasicAuth( USERNAME,PASSWORD )
#print (session.auth)
# Create a Zeep transport and set a reasonable timeout value
transport = Transport( session = session, timeout = 10 )
# strict=False is not always necessary, but it allows zeep to parse imperfect XML
settings = Settings( strict = False, xml_huge_tree = True )
# If debug output is requested, add the MyLoggingPlugin callback
#plugin = [ MyLoggingPlugin() ] if DEBUG else [ ]
# Create the Zeep client with the specified settings
client = Client( WSDL_FILE, settings = settings, transport = transport )
# Create the Zeep service binding to AXL at the specified CUCM
#Device Profile
def adduserdevprofile(enduserid,fullname, fname, lname, udpname, useremail):
userdp = {
'name':udpname,
'product':'Cisco 7965',
'model':'Cisco 7965',
'class':'Device Profile',
'protocol':'SCCP',
'phoneTemplateName':'your 7965 SCCP',
'softkeyTemplateName':'your User Softekey template',
'services':{
'service':[
'telecasterServiceName':'Corporate Directory',
'name':'Corporate Directory',
'urlButtonIndex':'1',
'urlLabel':'Corporate Directory',
'serviceNameAscii':'Corporate Directory'
'telecasterServiceName':'Login Logout',
'name':'Login Logout',
'urlButtonIndex':'2',
'urlLabel':'Login Logout',
'serviceNameAscii':'Login Logout'
try:
resp = service.addDeviceProfile(userdp)
print( '\nadd Device Profile response:\n' )
print( resp,'\n' )
print( f'Zeep error: add Device Profile: { err }' )
sys.exit( 1 )
def updatemultidp(devlines,udpname):
try:
print(udpname)
print(devlines)
resp = service.updateDeviceProfile(name = udpname,
lines = devlines)
print( '\nupdate Device Profile response:\n' )
print( resp,'\n' )
print( f'Zeep error: update Device Profile: { err }' )
sys.exit( 1 )
#Iterating through the Bulk Data
for users in data:
devices = {
'device': []
devlines = {
'line' : []
myphoneProfiles = {
'profileName' :[]
myusers = users.split(',')
blkdn = len(myusers)
enduserid = myusers[0]
print('This is the end user',enduserid)
userdn = myusers[6]
print(userdn)
extn = myusers[6]
udpname = myusers[2]
udevname = myusers[1]
devcss = myusers[7]
#print(udevname)
devices['device'].append(udevname)
myphoneProfiles['profileName'].append(udpname)
fname = myusers[3]
#print(fname)
lname = myusers[4]
#print(lname)
useremail = myusers[5]
#print(useremail)
plines = blkdn + 1
print(myusers)
j = 1
k = 7
l = 8
for i in range(6,blkdn,3):
lp = j
print(lp)
print(myusers[i])
userdn = myusers[i]
usercss = myusers[k]
fullname = myusers[l]
#for k in range(6,blkdn,2):
userline =  {
'index' :  lp,
'label' :  fullname,
'display' :  fullname,
'dirn' :  {
'pattern' : userdn,
'routePartitionName' :'Your_Phones_PRT',
'ringSetting' : 'Ring',
'consecutiveRingSetting' : 'Use System Default',
'displayAscii' :  fullname,
'mwlPolicy' : 'Use System Policy',
'maxNumCalls':'6',
'busyTrigger':'2',
'callInfoDisplay' : {
'callerName' :'false',
'callerNumber' :'false',
'redirectedNumber' :'false',
'dialedNumber' :'false'
'recordingFlag' : 'Call Recording Disabled',
'audibleMwi' : 'Default',
'associatedEndusers':{
'enduser':{
'userId':enduserid
'missedCallLogging' : 'true',
'recordingMediaSource' : 'Gateway Preferred'
devlines['line'].append(userline)
j=j+1
k = k+3
l = l+3
#print(devlines)
devlines.clear()
devices.clear()
print('after clearing',devlines)
#sample Bulk Input
#UserID,Jabber,DeviceProfile,FirstName,LastName,emailID,DirectoryNumber,CSS,LineASCII
