cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 03-04-2007 08:32:23 AM
When there is a currency amount over one hundred, there should be an "and" tying the amount together, for example,
1576.90, we should hear "one thousand, five hundred AND seventy six pounds AND ninety pence".
The first AND here is missing. How can we fix this? Please advise! Using Call Services 3.4 and say it smart.
Subject: RE: Currency Read Back Problem
Replied by: Vance Vagell on 03-04-2007 08:16:07 PM
Hi Karl,
The Currency Say It Smart (SIS) plugin leverages the Number SIS plugin to read back the number portions of its input. Since the Number SIS plugin does not use the word "and" (see the Number SIS plugin fileset and example output in the 3.4.x Say It Smart Specifications), the Currency SIS plugin does not use the word "and" in its numbers.
The Currency SIS plugin does include "and" in its fileset and examples, but it is only to read decimal points (e.g., "ten dollars AND two cents").
You have the option of either creating your own custom SIS plugin that reads currency back exactly as you'd like, or you may be able to extend the existing Currency SIS plugin to add the word "and" as desired. For information about creating a new SIS plugin, please refer to the 3.4.x Programmer Guide. For an example of an extended plugin, please see the NewDateInputFormat SIS plugin in our Sample Java Code forum.
Vance
Replied by: null on 03-04-2007 08:29:51 PM
Suggest you include an improvement for this.
Speak to your European Representative who will confirm this should be part of any internationalisation your include for SayItSmart.
Replied by: Vance Vagell on 03-04-2007 08:34:52 PM
Hi Karl,
Thanks for the feedback. I've sent a link to this discussion over to Kev Holmes, who works on that side of the Atlantic. If you have additional follow-up regarding this, please get in touch with him and he can pick up where this thread leaves off.
Vance
Subject: Services abound for this
Replied by: Cory Wright on 03-04-2007 08:41:30 PM
Hey Karl,
Just read your feedback.
Have you taken the training class for the software? The Say It Smart plug-in architecture is really powerful and creates a wide open playing field for developers to have a ball with it.
For example, we have a partner who developed Portuguese Say It Smart plug-ins to meet a variety of local needs.
Also, we have seen plug-ins created that map the international airport codes to various spelled-out languages.
Seems to me that is way more powerful than creating a country-specific standard that goes into the software. We basically let you do anything you want! We heard from developers that this is what they wanted as a much higher priority than us delivering point-by-point solutions.
Cory
Subject: RE: Services abound for this
Replied by: null on 03-04-2007 09:09:40 PM
Thanks Cory,
Problem is this has cropped up in testing on a large project and we're two weeks for the deadline with plenty of other things to keep us occupied.
I can't see me booking a training course. Audium isn't difficult (you should see some of the java we're written around it), however little things like the "and" thing raised as a bug by the customer is annoying. On the face of it the functionality is there, but this little one creeps out.
I accept generally what you say, but would apply to totally new formats not base ones.
If you can share a "currency" version of the date, and fast track us, maybe we can quickly fix this problem. Its not that we can't do it - we have exceptionally clever people, just time is against us with other things on the go.
Hope you understand!
Any help here appreciated and we can take this offline if you wish.
Replied by: null on 04-04-2007 07:03:11 AM
Hi Karl,
I'm afraid the issue is a little wider than just currency; it applies to numbers in general. The good news is that we're in the late stages of testing an internationalisation pack that addresses this feature, and several others too. This pack is a set of generic templates to which parameter files can be applied to implement specific languages - this is so a new language variant can be created using local expertise rather than requiring a change to the central code base by non-native speakers.
I'll call you on this later
Replied by: null on 20-04-2007 08:02:09 PM
We rewrote the entire say it smart class for currency and it just works. Just to complete this.
We rewrote the entire say it smart class for date so it much more localised. Another rewrite.
Subject: SIS Plug ins!
Replied by: Cory Wright on 27-04-2007 02:41:22 PM
Karl,
Nice work! That's exactly what SayItSmart plugins are for -- to customize and localize, or localise , whatever you need to do.
We had another partner that developed Portuguese SayItSmart plugins for a project last year.
If you want to share, feel free to post it up!
Cory
