cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jonas Kjellberg on 19-10-2011 12:13:18 PM
We have created a new layout family and our custom built layouts works perfectly until we choose computer as presentation source. The AMX sends a start presentation command only, no added layouts or frames are sent from the AMX.
We have a C90 connected with three cameras, one pc and everything is controlled by an AMX unit. In the controller room we have two monitors. The layout is created in TC Console.Layout basically is doing the following the left monitor (3) shows remote participants and own main. the right monitor(4) shows all local inputs (3 cameras + 1 PC).
What happens when we press the computer presentation button the custom layout "crashes" instead of using the our custom built layout C90 uses a default layout fullscreen mode instead of the custom layout I have created with TC Console. It does not matter if I choose pc presentation from remote control or push the presentation PC button on the AMX. Same thing happens.
If I choose to use any camera as a presentation source, my custom layout is working as expected. Why is this happening?
After reading through the forums I can see that some customers creates the custom layouts in AMX and sends them to the codec.
Do you recommend to always create/force layout in the AMX and send it to the codec?
Can you help me solve this issue?
XML is uploaded. I did create a new xml file from scratch, but the same thing happens. Is it a presentation or input setting i have missed?
Thanks in advance
/Jonas
Subject: RE: Custom built layout issue C90.
Replied by: David Bruun-Lie on 19-10-2011 01:18:54 PM
Jonas,
can you try the attached XML file (TC console, File - Open)? I have made some small adjustments that look like they may have been caused by a bug in the TC application.
This XML, was it initially created in a previous/older version of TC console?
Cheers,
David
Replied by: Jonas Kjellberg on 19-10-2011 04:35:54 PM
David A Bruun-Lie:
Jonas,
Cheers,
David
Hi David
I tried your XML but it is still the same problem. Whenever I use computer as presentation source it wont use the custom made layout.
I will upload another XML for you and see if you can try to fix this one instead. If I use any other source than PC for presentation, cam1,cam2 or cam3 it is working.
The XML was created with the latest TC Console.
Thanks in advance.
/Jonas
Replied by: David Bruun-Lie on 21-10-2011 03:21:53 PM
Jonas,
I assume the PC-input is of 4:3 format and 16:9? Seems to be a bug in the TC console that 4:3 formats (e.g. 1024x768) get wrong layouts. Is it an option for you to have 16:9 output from the PC?
Regarding manually editing the XML file for you I have to wait until Monday as I need to discuss it with some of the developers to understand just exactly is going on - sorry
David
Replied by: Jonas Kjellberg on 24-10-2011 08:16:02 AM
David A Bruun-Lie:
Jonas,
David
Hi David.
You are absolutely right, we fixed it ourselves last friday evening. Thanks for your help. we solved the problem by a small notice...we saw in the help section of Tc Console that to the old version had three columns.4:3 was back then included as an option. We have now edited our xml so it acts the same way whether its 4:3 or 16:9.
It is not an option for us to have 16:9 since the projector in the auditorium only supports 4:3.
I am uploading the working XML if someone has the same problem.
Thank you very much David!
/Jonas
